Sony Vfet Illustrated build guide
Old 21st February 2020, 11:38 AM   #1011
Dennis Hui is offline Dennis Hui  Canada
Hoopy Frood
Very nice Paul. Congratulations!
We are fearless amplifier builders. A little heat doesn't scare us at all.
- NP 2002
Old 21st February 2020, 11:46 AM   #1012
Eric is offline Eric  United States
Eric's Avatar
What a nice, clean looking build, Paul. Well done!
DIY Theater, Aleph-X Amps, LDR based BA-3 pre, B1 Korg, Pearl II, modified SL-1200 TT, F4, M2, Aleph-J, MoFo, a40, VFet-2, ACAs, FHXL & TB 1772 speakers
Old 21st February 2020, 12:34 PM   #1013
flocchini is offline flocchini  United States
Beautiful
Old 21st February 2020, 03:50 PM   #1014
ItsAllInMyHead is offline ItsAllInMyHead  United States
Gorgeous!
If you want a friend, feed any animal - Perry Farrell
Old 21st February 2020, 10:50 PM   #1015
JeffYoung is offline JeffYoung  Ireland
JeffYoung's Avatar
Indeed, nicely done!
Old 22nd February 2020, 12:14 AM   #1016
poseidonsvoice is offline poseidonsvoice  United States
poseidonsvoice's Avatar
Paul,
Outstanding. Not to mention the improved measurements if a balanced source is used since you are cancelling the 2nd order harmonic with your build. I figure for an 8 ohm load... you should get about 30 watts at 1% THD? Output impedance should rise to 0.36 ohms or a damping factor of 22.5. I hope you enjoy this build for years to come.
Best,
Anand.
Science is not a democracy - Earl Geddes
DIYAudio is a journey not a destination!
Old 22nd February 2020, 02:06 AM   #1017
PierreQuiRoule is offline PierreQuiRoule  Canada
PierreQuiRoule's Avatar
Paul - They are beautiful. Thank you for sharing !
Old 22nd February 2020, 02:12 AM   #1018
twitchie is offline twitchie  Canada
Magic Smoke Liberator
So great to see more beautiful amps from Canada! Great job Paul!
Old 22nd February 2020, 09:02 PM   #1019
Sabrosa is offline Sabrosa  United States
Paul, and others who've designed faceplates thicker than 10mm, did you CNC the front panels yourself, or are there shops out there who will machine larger pieces? Front Panel Express and Modushop both max out at 10mm. Does anyone have recommendations for other machining services that can work with 15 or 20mm designs?
Old 23rd February 2020, 06:23 PM   #1020
Enochrome is offline Enochrome  United States
I have the opportunity to get a Sony ta-5650. The owner says that the light turns on when powering on but it does not give out sound. Beyond opening it up are there any ways to indicate that the VFETS are ok?
Thanks,
Sony Vfet Illustrated build guideHide this!Advertise here!
Aleph J illustrated build guide 6L6 Pass Labs 5263 Today 07:22 PM
BA-3 Amplifier illustrated build guide 6L6 Pass Labs 325 Today 02:43 AM
F6 Illustrated Build Guide 6L6 Pass Labs 2122 Yesterday 09:19 PM
F5Turbo Illustrated Build Guide 6L6 Pass Labs 598 2nd July 2020 10:30 PM
ACA illustrated build guide 6L6 Pass Labs 169 16th June 2020 03:12 PM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
Copyright ©1999-2020 diyAudio
