Home | Forums | Rules | Articles | diyAudio Store | Blogs | Gallery | Wiki | Register | Donations | FAQ | Calendar | Search | Today's Posts | Mark Forums Read | Search |
Pass Labs This forum is dedicated to Pass Labs discussion. |
#201 |
Bravo Jesper! You've been very productive building a whole new system this winter
#202 | |
The schematic is final... I have shorted (omitted) the C1 capacitor, which is only used for balanced operations. -Some other values is changed a bit, mostly to use what i allready got in drawer. I asked didiet78 to make the changes on his schematic and pcblayout; but due he is busy at work he didn't find the time to it yet... This is hobby right ![]() The PSU i have designed with Duncans psu designer. The PSU is dual mono (2 x torids, 4 x rectivers, 4 x 33000uF, etc...) Unfortunately my schematic and pcblayout have gone due to some computer crash ![]() I use two 120VA 15-0 15-0 torids, giving ~+19vdc 0 -19vdc rails, feeding the AlephJ_Mimi's. If it was not because i allready got one of the torids, i would have chosen two 200VA types, but the ones i use, do the job fine... no problems. The original minialeph, which has been around for many years, use also 15v torids, so we (ZM and others) did the calculations for that voltage. I think lower voltage is needed also for bringing the dissipation down, giving space for higher bias! The chassis i use, goes around 50C or so, after many hours yesterday... so that is good i suppose. Good luck. Schematic changes : R27' (Potentiometer) = 100K ohm (Was 50K) R27 = 10K ohm (Was 47K) R6 = 825 ohm (Was 800 ohm) R12 = 221 ohm (Was 220 ohm) R26 = 3,32K (Was 3,3K) As i wrote earlier... sound is amazing, and setup is deadquiet... Jesper.
DCG3 Dual DCSTB, AK4490 Dual SuperDAC ![]() AlephJ Mimi! http://www.diyaudio.com/forums/pass-...mimi-mini.html |
#203 |
Nice! Also, because this is my first dive in Pass Labs I can't find info about Q5 and Q8. Perhaps they are mentioned somewhere in this thread and I missed it...
#204 | |
![]() Jesper.
#205 |
Thanks Jesper! Coming soon... or later, but it will be for sure!
#206 | |
It is what i used... I was in luck, having some 2sj109 in drawer, which was old but working. Jesper.
#207 |
Good to know! It seems we have to wait for Didiet78 - no rush at all - and then gather updated schems and PCB in one post.
#208 |
As soon as i got the material, i will update post #1, to contain all information needed...
Jesper.
#209 |
Hi again!
I hope Jesper enjoys his amp! I really would like to give it a try too. But I need to ask about some possible modifications. My speakers require a couple of watts in average but they can benefit from large headroom. From the little I know and read about transistors, the max output power is related to the psu voltage rails. So I'm thinking to move from +/- 16V back to +/-24V. But this means increaced power dissipation. I could bias for lower idle current or could I? Would this affect performance/sound quality? Is there a safe minimum? OTOH, if the hotter the bias, the better the sound then is good to know and take my decisions about heatsinks...And a last question; How does bias affect the gain of this amp? Thanks and please excuse me for this short hijacking. |
#210 | |
![]() A few post before this, i wrote the changes i did to the values! .. I think Didiet78 is a busy man at present; i asked him, if he could send me a new schematic and maybee a layout for 2SJ74's (The actual layout is for 2SJ109) But hey this is DIY, and Didiet78 allready did an excellent job here ![]() Regarding the technical specs. I think it is no problem regarding sound quality, but about raising the rails to 24v could be some parts have to change? We hope an X fingers that ZM would look at this! I am for sure satisfied with my amp. as is now! Jesper.
Thread | Thread Starter | Forum | Replies | Last Post |
FS: Babelfish J Mini version | acamilicko | Swap Meet | 3 | 7th August 2017 05:09 PM |
FS: PreAmp with Complimentary JFET Diff input & JFET ouput | USAcircuits | Vendor's Bazaar | 12 | 21st June 2011 12:02 PM |
Jfet input for Aleph 60? | Dansk | Pass Labs | 14 | 22nd January 2011 02:34 PM |
Aleph Mini with JFET input? | Arie | Pass Labs | 11 | 21st March 2008 06:42 PM |
A chopped Mini-A with Jfet input stage | Fuling | Pass Labs | 12 | 15th November 2006 08:45 PM |
New To Site? | Need Help? |
