AlephJ Mimi! (Mini)
AlephJ Mimi! (Mini)
Old 9th January 2017, 07:00 PM   #111
lykkedk is offline lykkedk  Denmark
lykkedk's Avatar
Default One channel up
Originally Posted by Zen Mod View Post
aha
in spirit of the day , you can name it Aleph SissyJ
Maybee....
But https://www.youtube.com/watch?v=nzkubfTPDaU ...
AlephJ Mimi is now set at Bias ~1,3A.(NON Sissy Bias) DC-offset is pending up/down very stable near "0"...
Going much higher on volume on my DCG3 (2xgain) preamp will be to much Speaker(s) are 90dB
I am really amazed by first impression!... not that i can tell anything about soundquality, but amp. is completely quiet; even with all cables messed up like a birds nest
So we (*I) now know that amp. is giving enough gain/voltageswing for my system to be played to the max. -Perfect.
Hope you enjoy my video... just for fun
Jesper.
DCG3 Dual DCSTB, AK4490 Dual SuperDAC
AlephJ Mimi! http://www.diyaudio.com/forums/pass-...mimi-mini.html
Old 9th January 2017, 07:18 PM   #112
Zen Mod is offline Zen Mod  Serbia
Official Court Jester
Zen Mod's Avatar
AlephJ Mimi! (Mini)
I can bet that pleasure will be quadruple , when you double channels
my Papa is smarter than your Nelson !
clean thread; Cook Book;PSM LS Cook Book;Baby DiyA ;Mighty ZM's Bloggg;Papatreasure;Papa...© by Mighty ZM
Old 10th January 2017, 12:53 AM   #113
didiet78 is online now didiet78  Indonesia
No burn mark under 0.47 ohm ?
Didiet
Usb I2S + AK4490 / WM8805+ESS9023 / SDHC Card I2S audio player + AD1860
Old 10th January 2017, 01:33 AM   #114
woody is offline woody
Any chance of the boards being available ?
Old 10th January 2017, 02:57 PM   #115
lykkedk's Avatar
Hello.
The board is only proto (one channel); and i need Didiet78 to make some small changes for me. -The board i created is also NON ums (non diyaudio standerd), so this also have to be considered.
Some of mine precious parts (some capacitors and the 2sj109V) is also parts, which should not be made in a "groupbuy" or like pcb i think.
But i think Didiet78 also have an UMS board ready by now.
I will take contact with the pcbmaster later tonight!, and see if he is able to make some small changes for me?
Let's see future on, i am not nearly finish yet.
Thanks for following my thread
Jesper.
Old 11th January 2017, 01:13 AM   #116
Standard Aleph J availabe on DIY Audio Store
Didiet
Old 11th January 2017, 06:48 AM   #117
lykkedk's Avatar
Default Dual torrids possible in firstwatt PSU ?
Hello.
For testing two channels, i need a bigger torrid than the one 120VA i got now.
I am planning to do dual PSU in one chassis.
I can still source a torid like the one i allready got, so two identical torrids.
But i am in doubt if it's possible to use two torrids on the same PSU, for testing.
It will be some time before i will make new psu boards, so testing with my old one, would be nice!
Anybody know that???
0120P1-2-015 | 2 Output Toroidal Transformer, 120VA, 2 x 15V ac | Nuvotem Talema
Jesper.
Old 11th January 2017, 08:24 AM   #118
Zen Mod's Avatar
AlephJ Mimi! (Mini)
I would believe them (enough for paralleling of secondaries) only if they're wound bifilary
in any other case , each secondary get dedicated bridge , then do whatever you want
good thing is that you can use smaller bridges for that
Old 11th January 2017, 09:35 AM   #119
lykkedk's Avatar
So looking at datasheet of that torrid, say's parallel and seriel is possible.
I also once paralled a torid, without problems.
Quistion is more about, how psu is reacting on this?
Product Details
Open Style with Leads, 15VA to 1000VA
High quality open style toroidal transformers with a single 230Vac 50/60Hz primary winding. Twin secondary windings may be connected in series or parallel or used independently.
Old 11th January 2017, 09:37 AM   #120
Zen Mod's Avatar
AlephJ Mimi! (Mini)
I can't see nothing wrong
AlephJ Mimi! (Mini)Hide this!Advertise here!
FS: Babelfish J Mini version acamilicko Swap Meet 3 7th August 2017 05:09 PM
FS: PreAmp with Complimentary JFET Diff input & JFET ouput USAcircuits Vendor's Bazaar 12 21st June 2011 12:02 PM
Jfet input for Aleph 60? Dansk Pass Labs 14 22nd January 2011 02:34 PM
Aleph Mini with JFET input? Arie Pass Labs 11 21st March 2008 06:42 PM
A chopped Mini-A with Jfet input stage Fuling Pass Labs 12 15th November 2006 08:45 PM
Copyright ©1999-2019 diyAudio
