Home | Forums | Rules | Articles | diyAudio Store | Blogs | Gallery | Wiki | Register | Donations | FAQ | Calendar | Search | Today's Posts | Mark Forums Read | Search |
Pass Labs This forum is dedicated to Pass Labs discussion. |
#101 |
Very nice.
"If you leave this point unattached to some circuitry, an ideal constant current source will emit a small lightning bolt which will travel until it connects to something." Nelson Pass |
#102 | |
Official Court Jester
also , it helps if you have mosfets mounted on heatsink ![]()
my Papa is smarter than your Nelson ! clean ![]() ![]() ![]() |
#103 |
![]() ![]() I powered up our little AlephJ (Renamed to Alepj_Mimi!) Accecdentily i renamed some pictures to _Mimi!, so hereby a new name... tadaa : AlephJ_Mimi! ... Cool yes ? ![]() Some of the parts are slightly different from schematic, but not much; i will ofcause post that later on, when prober testing is done. Bias is easily adjusted, up/down around 0.6V (1,27A Bias)... I figured out that voltage divided by sourceresistor (eg. 0.6/0.47 = 1.2A)... Silly me i should have know that before i asked that yesterday Sry... After a short while, without prober heatsinking devices are heating up. DC-offset was a little jumpy for a start, but after 30sec. it was also good enough to adjust... So i guess circuit is working. Next week i will try mounting heatsinks, and ofcause adjust the thing for good. Thanks everybody for helping me, get this far by now. Good sunday! Jesper.
DCG3 Dual DCSTB, AK4490 Dual SuperDAC ![]() AlephJ Mimi! http://www.diyaudio.com/forums/pass-...mimi-mini.html |
#104 |
Congrats mate
#105 |
Morning.
I have mounted some heatsinks, which size should match the dissipation (i hope), for our MiniAmp. here. Rail is with this PSU ~ -19 "0" +19 vdc. I tried setting bias at 0.61 (~1.3A), but source resistors/mosfets are getting hot to the touch. Setting Bias around 0.51 (~1A) is much better. I just remember, that i read somewhere Bias should be set to no less than 1.2A ? -Can't remember where i read this? -And why? Can someone comment on this ? - I mean, what is pros and cons ? - Later today i will try listning to some recordings, to hear if Amp. is swinging enough watts for my setup! Really exciting ![]() Jesper.
#106 |
At 1.3 A, 0.47Ohm resistor is only dissipating 1.3 x 1.3 x 0.47 = 0.8Watts
Set at 1.3A and stop worrying about it. This is a single ended amp (not push pull), you want as much bias current as the mosfets, and your heatsinks allow, so set at 1.3A and stop worrying about it.
#107 |
all Danes are having same heatsinks
#108 |
You allready know that ZM
![]() I am lucky, that mine is partly, so i can use lower half, for making a lower chassis. Jesper.
#109 |
aha
in spirit of the day , you can name it Aleph SissyJ ![]()
#110 | |
I see the point here. Running at 1.3A will give near 25w pro mosfet, and 100w for stereo, which is i think perfect. I will start it up again and cranck bias to 0.6 now... Too be continuied ![]() Jesper.
Thread | Thread Starter | Forum | Replies | Last Post |
FS: Babelfish J Mini version | acamilicko | Swap Meet | 3 | 7th August 2017 05:09 PM |
FS: PreAmp with Complimentary JFET Diff input & JFET ouput | USAcircuits | Vendor's Bazaar | 12 | 21st June 2011 12:02 PM |
Jfet input for Aleph 60? | Dansk | Pass Labs | 14 | 22nd January 2011 02:34 PM |
Aleph Mini with JFET input? | Arie | Pass Labs | 11 | 21st March 2008 06:42 PM |
A chopped Mini-A with Jfet input stage | Fuling | Pass Labs | 12 | 15th November 2006 08:45 PM |
New To Site? | Need Help? |
