F4 Beast Builders
F4 Beast Builders
Old 6th December 2016, 11:35 PM   #21
lhquam is offline lhquam  United States
Originally Posted by 2 picoDumbs View Post
I sssume that simulation is done with thermistor at exact same temperature as mosfet.
Generg's is mounted on heatsink.
Is it possible to simulate the effect of mounting the thermistor in different locations.
I agree that the thermistor mounting location is important. But the junction to heatsink temperature rise is only about 0.2C/W with the IXSYS SOT-227B packages. That means that at 1.3A and @24V the junction temperature is only about 6.3C hotter than the heatsink. I do not think it is a problem.
Old 7th December 2016, 12:25 AM   #22
2 picoDumbs is offline 2 picoDumbs  Australia
2 picoDumbs's Avatar
I don't think it is a problem either.
I am however interested to see the response due to the lag time required for the heatsink temperature to hit equilibrium with the mosfet.
Not concerned just interested.
Probably not easy to model I guess.
"If you leave this point unattached to some circuitry, an ideal constant current source will emit a small lightning bolt which will travel until it connects to something." Nelson Pass
Old 7th December 2016, 03:00 PM   #23
plasnu is offline plasnu  United States
I'm astound by how you guys are meticulously deciphering Pa's secret message...
Old 7th December 2016, 03:02 PM   #24
generg is offline generg  Germany
generg's Avatar
F4 Beast Builders
nobody knows how the XA25 really looks.... it is only playing and enjoying and showing Pa that we can play a bit....and all his gifts were not in vain.... :-))
and the First Wtt is......a really First Class PSS Idea
Old 7th December 2016, 03:19 PM   #25
With no board photos, the XA25 is definitely more of a challenge.
Old 7th December 2016, 05:34 PM   #26
generg's Avatar
F4 Beast Builders
In the case Spice is right the very low distortion values Nelson states are for me only available with cascoded output and with some bootstrapping of the cascode transistors.
What do you think lhquam?
Old 7th December 2016, 05:41 PM   #27
Zen Mod is offline Zen Mod  Serbia
Official Court Jester
Zen Mod's Avatar
F4 Beast Builders
solder fumes time
and , if possible , cousin at IXYS , to send multiple freebies , for testing
my Papa is smarter than your Nelson !
clean thread; Cook Book;PSM LS Cook Book;Baby DiyA ;Mighty ZM's Bloggg;Papatreasure;Papa...© by Mighty ZM
Old 7th December 2016, 05:42 PM   #28
Dennis Hui is offline Dennis Hui  Canada
F4 Beast Builders
Originally Posted by generg View Post
And I tell you I am deeply impressed by the clarity and finesse of sound!
So Nelson real XA25 must be heavenly!
Generg, it seems you've already built a wonderful amp. Congratulations!
Dennis
We are fearless amplifier builders. A little heat doesn't scare us at all.
- NP 2002
Old 7th December 2016, 06:01 PM   #29
generg's Avatar
F4 Beast Builders
Originally Posted by Zen Mod View Post
solder fumes time
ha, ha, no cousin... but four P and four N are available at my home.
In the Sony II paper Nelson writes "There is one other detail in the output stage regulation; R17/C7 and R18/C8
which bootstrap the Cascode power transistors with about a one-sixth version of
the output waveform so as to get a little more voltage swing at maximum and
bring the output VFETs a little closer to the “sweet spot” of their load line curve."
Of course this detail is crying to be used in the "F4 beast" too.
I am only unsure where to measure the "one-sixth" waveform to get the right R.
And of course "one-sixth" might only be correct for the Sony II.
These are the limits of a box of bricks amp builder....
Old 7th December 2016, 06:02 PM   #30
generg's Avatar
F4 Beast Builders
Dennis
yes it is true, I now go hearing again....
F4 Beast BuildersHide this!Advertise here!
Stereo F4 comparison to twinn F4 monoblocks Manolo47 Pass Labs 0 21st November 2016 01:25 PM
Orion Beast mbates14 Car Audio 0 20th March 2013 10:21 PM
A Bride for a Beast? Johnloudb Pass Labs 6 29th November 2009 12:10 AM
F4 Builders in Germany Flecko Pass Labs 0 25th February 2008 06:37 PM
The Beast... sklimek Tubes / Valves 5 29th June 2005 04:04 PM
