threshold s200
Hello, here are the photos.
Can you tell me where I have to make the measurement with the multimeter?
I replaced the trimpot with a better (SLAB) and especially more accessible for adjustment !!
regards
gilles
Official Court Jester
Joined 2003
well , you being Frenchy , moi being Serb ...... writing on Engrish ...... there surely must be some hiccup :rofl:
you have non-repaired side , with proper temperature on heatsink;
measure voltage across one emiter resistor (big 1R thingie , any of them) and take that as reference ;
move voltmeter on other side emiter resistor (cold channel) , and re-bias it , to have approx. same voltage across resitor and similar temp on heatsink ..... as other (untouched) channel
if both are well under desired heatsink temperature , re-bias them both
Joined 2003
something's wrong - 180mV across 1 Ohm , for 45C
and 320mV for 22C
be sure that you're checking same positioned resistors , pcbs are the same .......
recheck other 1R resistors , that way you'll also know is some output transistor gone Dodo
if these resistors are looking good ( no cracks ) and measure good (resistance) , there is no need to change them
