SIT Nemesis
SIT Nemesis
Old 14th March 2018, 06:11 PM   #61
Michael Rothacher is offline Michael Rothacher  United States
AudioMaker.Tech
Michael Rothacher's Avatar
SIT Nemesis
Did you also measure the 8-ohm secondary?
Visit AudioMaker.Tech
Old 14th March 2018, 06:48 PM   #62
nagini262 is offline nagini262  Viet Nam
nagini262's Avatar
Oh, I will measure 8 ohm tap secondary and tell you soon.
Music makes sublimation joy, help alleviate grief, soothe the pains and repel any resentment!
Old 15th March 2018, 02:12 AM   #63
nagini262's Avatar
Hi Mike!
I measured the 8 ohm tap secondary: (@100Hz)
+ L = 35.7mH
+ Rac = 6.86 ohm
+ Rdc = 0.61 ohm
Old 15th March 2018, 02:07 PM   #64
AudioMaker.Tech
SIT Nemesis
Thank you. Do you use LTspice?
Old 15th March 2018, 06:55 PM   #65
nagini262's Avatar
Unfortunately, I'm not use LTspice
I will build this amp with 100v/0.8A, I really don't like to use regulator so I will use choke input as LCLC filter. Just a little hard to find a good capacitor with high voltage.
Old 15th March 2018, 08:04 PM   #66
AudioMaker.Tech
SIT Nemesis
I haven't plugged your new figures into the simulation yet, so hold your horses.
Old 15th March 2018, 08:32 PM   #67
AudioMaker.Tech
SIT Nemesis
Try 32-ohm pri, 8-ohm sec, B+=80V, Id = 1.1A .2% @ 1W if the sim is to be believed.
Old 15th March 2018, 08:51 PM   #68
AudioMaker.Tech
SIT Nemesis
Bias voltage needs to be steady.
Old 16th March 2018, 04:13 AM   #69
nagini262's Avatar
Many thanks for your help! I will try and tell you the result. I have some experience about bias for vfet so I will take care about this and make sure the bias voltage start up first and after that a timer will turn on B+.
Old 16th March 2018, 02:45 PM   #70
AudioMaker.Tech
SIT Nemesis
The device dissipation is a little bit high, you can lower the bias or be FAB.
Have fun,
Mike
SIT NemesisHide this!Advertise here!
The Arch Nemesis jan.didden Pass Labs 16 19th April 2016 01:24 AM
Ultrasimple SIT PP amp from BAF , or SIT Beast with a Thousand PSUs Zen Mod Pass Labs 347 19th August 2015 05:27 PM
SIT-1 and SIT-2 owner manuals Nelson Pass Pass Labs 25 12th September 2012 08:16 PM
Nemesis tonistefanovski Instruments and Amps 1 12th May 2006 06:41 PM
Help on Nemesis amp RichardJones Solid State 10 16th July 2004 05:57 PM
