50w Single-Ended BAF2015 Schade Enabled
Old 12th November 2019, 04:15 AM   #931
Ben Mah is offline Ben Mah  Canada
Originally Posted by Itsmee View Post
Hopefully it's right this time.
Bad news!
Something that I didn't catch last time - pin 5, not pin 6, of the 4N35 connects to the 1000uF cap positive terminal.
In your switch-around of Drain and Source, some of the connections were messed up. Your 4N35 pins 2 and 4 and 1000uF cap negative is now connected to the speaker out (O/P). It should be connected to "A" on your board.
Maybe fourth time lucky.
Old 12th November 2019, 04:40 AM   #932
Originally Posted by dantwomey View Post
I owe Ben a cold beverage. He caught a flaw on my schematic!
BAF 2020? I've been hanging out with your fellow Torontonian Dennis Hui here in SF.
Old 12th November 2019, 08:05 AM   #933
Itsmee is offline Itsmee  England
Itsmee's Avatar
Thanks Ben, last go.
Simple circuit, can't believe I keep cocking it up!
Old 13th November 2019, 03:12 PM   #934
vdi_nenna is offline vdi_nenna  United States
vdi_nenna's Avatar
I thought it was simple too until I tried to P2P this circuit.
Made me humble. I'm 0 for 2 in my last two amp builds.
I need a win!
I build, therefore I am.
Do not create problems where there are none.
Old 13th November 2019, 03:55 PM   #935
analog_sa is online now analog_sa  Europe
analog_sa's Avatar
Being a bit stupid i always follow the workflow: schematic > netlist > pcb. Even for something simple. In the long run it is better for documentation and maintenance. It also excludes any possibility for the pcb not to match the schematic.
Old 13th November 2019, 07:03 PM   #936
Itsmee's Avatar
Originally Posted by analog_sa View Post
...i always follow the workflow: schematic > netlist > pcb...
That's the correct way; working free hand isn't usually a problem as I would normally print the schematic and component pin-outs as I layout; then check off the circuit layout against the schematic using highlight pen as I go.
At the moment, I don't have a working printer
I should buy one, better still, learn to do it properly
Old 13th November 2019, 09:17 PM   #937
dantwomey is offline dantwomey  Canada
If you're using a SOT-227 device I have some spare PCBs I'm willing to share for a modest fee.
Dan
Old 13th November 2019, 11:38 PM   #938
Itsmee's Avatar
I ordered the last version, the boards should be here in a couple of days, if they go bang, i'll give you a shout, thank you for the offer.
50w Single-Ended BAF2015 Schade EnabledHide this!Advertise here!
Single tube, Single ended, 20W, impossible? dannydanger Tubes / Valves 39 1st June 2017 09:18 PM
Single High power Mosfet for big Single Ended Amp ? Ado Solid State 20 25th February 2016 04:32 AM
Single Ended, Single driver: In-room distortion measurements Gerrit Boers Full Range 4 27th November 2007 09:12 AM
Anyone play with the Zen Single-Stage Single-Ended Class A? Rino odorico Pass Labs 13 29th August 2002 10:01 AM
Copyright ©1999-2019 diyAudio
