50w Single-Ended BAF2015 Schade Enabled
Old 5th May 2016, 01:35 AM   #21
RobLK is offline RobLK  United States
Yes, with some of the noctua fans you need to have your ear pretty close before you hear them. You don't need much cfm to make a big difference in cooling either. The air needs to be pushed through the fins of the heat sink. Figure 6 in this link shows how much difference it can make with just a little cfm.
How to Select a Suitable Heat Sink
Old 5th May 2016, 01:44 AM   #22
vdi_nenna is offline vdi_nenna  United States
vdi_nenna's Avatar
Originally Posted by 2 picoDumbs View Post
I'm still undecided whether a nice raw hack job or do a pcb.
You could do this one blindfolded!
I build, therefore I am.
Do not create problems where there are none.
Old 5th May 2016, 02:36 AM   #23
2 picoDumbs is offline 2 picoDumbs  Australia
2 picoDumbs's Avatar
Might need to do a pcb for transformer if the pins don't line up on proto board.
The rest should be doable hack style.
"If you leave this point unattached to some circuitry, an ideal constant current source will emit a small lightning bolt which will travel until it connects to something." Nelson Pass
Old 5th May 2016, 04:39 AM   #24
Superstrand is offline Superstrand  United States
Superstrand's Avatar
Untested DRAFT PCB layout for comment. It will cost me the same to buy two boards as it will six, so I'll donate and ship two pairs to anyone interested in helping to prototype the hockey puck "sh*t amp."
Old 5th May 2016, 04:42 AM   #25
First up.
The 10uF cap at output is intended to be a polypropylene cap not an electrolytic.
Old 5th May 2016, 04:46 AM   #26
For R4 and R5 it might be worthwhile allowing paralleled pairs of resistors.
Old 5th May 2016, 04:49 AM   #27
First up.
GOOD CATCH!!
Ill wait a bit until the rest of my mistakes are discovered and then post a revision!
Old 5th May 2016, 05:01 AM   #28
What lead spacing and diameter have you allowed for the 1000uF caps.
Some people are anal about using Elna Silmic Caps, so something to consider.
Old 5th May 2016, 06:17 AM   #29
Lead spacing on 1000mfd caps is 7.5mm which I believe is the spacing for the highest voltage 18x40 Elnas.
Old 5th May 2016, 07:01 AM   #30
Thanks, here's a revision with your suggestions!
50w Single-Ended BAF2015 Schade EnabledHide this!Advertise here!
Single tube, Single ended, 20W, impossible? dannydanger Tubes / Valves 39 1st June 2017 09:18 PM
Single High power Mosfet for big Single Ended Amp ? Ado Solid State 20 25th February 2016 04:32 AM
Single Ended, Single driver: In-room distortion measurements Gerrit Boers Full Range 4 27th November 2007 09:12 AM
Anyone play with the Zen Single-Stage Single-Ended Class A? Rino odorico Pass Labs 13 29th August 2002 10:01 AM
Copyright ©1999-2019 diyAudio
