Hammond 159zl as clc choke
Old 27th February 2016, 05:10 AM   #1
Hikari1 is offline Hikari1  United States
Default Hammond 159zl as clc choke
So...I just tried a pair of Hammond 159zl chokes in my f5. 23v rails, dual pair of mosfets. Replaced crc setup. Whoa. Iam liking what I am hearing. It's not placebo.
Do these things (Hammond chokes) break in?
What's the best place or position in the chassis to put them? I could mount the further away from the boards with farther leads or closer to the caps with shorter leads.
Is it advisable to twist the in/out wires on the chokes?
Old 27th February 2016, 05:39 AM   #2
John C is offline John C  United Kingdom
John C's Avatar
there may be a break in period..
I would tend to keep the leads short
I would not twist the in/out wires as you may couple noise from the in wire to the out wire.
L8TER... JC
Old 27th February 2016, 09:05 AM   #3
Zen Mod is online now Zen Mod  Serbia
Official Court Jester
Zen Mod's Avatar
they will break if they fall from enough distance from ground
away from pcbs is better
twist every pair of wire with slightest amount of AC across them ; so - twist those too
my Papa is smarter than your Nelson !
clean thread; Cook Book;PSM LS Cook Book;Baby DiyA ;Mighty ZM's Bloggg;Papatreasure;Papa... by Mighty ZM
Old 27th February 2016, 10:38 AM   #4
wdecho is offline wdecho  United States
I have thought about putting some chokes in my PS so this is good news. I did not think it would effect the sound too much is the reason I have not. Chokes are pretty common in Tube amps.
Nothing to settle in or break in. It's just coils of wire making an electromagnet. Being an electromagnet it does, as Zen says, have a field around it.
Old 27th February 2016, 01:38 PM   #5
eduard is offline eduard  Netherlands
Send a message via Yahoo to eduard
Hello,
I have been using Hammond and Lundahl chokes in both high and low current circuits.
Take a look at the following link.
Lundahl Transformers - Tube amplifier transformers
Greetings, Edward
P.s on his website there is also some info about higher admissable current to the lundahl filament chokes when the voltage is lower> Because Pass amps use very moderate dc voltages it can possible to use a choke with high mH rating. I would not worry to much about dc serie resistance
Old 27th February 2016, 10:27 PM   #6
tubesguy is offline tubesguy  United States
I have a pair that are currently not being used. If you're interested in experimenting, and would like to borrow them, let me know. - Pat
Old 27th February 2016, 10:49 PM   #7
woody is online now woody
Speaker City has some 2 mh 6A close out chokes for $6.95 each plus shipping . Probably not enough current rating for a stereo F5 but might be fine for monoblocks. Another down
side to these cheep chokes is they are unbelievably ugly !
Old 28th February 2016, 12:18 AM   #8
Thanks for the offer. I am starting on another tube amp next week so I am going to be busy with it. As for a good reasonable priced choke, I have used these extensively in tube builds with good results even when 10hy was specified.
C-14X Triad Magnetics | Mouser
Old 28th February 2016, 01:14 AM   #9
mcandmar is offline mcandmar
Hammond and Triad both have a good selection of chokes for tube use..
Hammond Mfg. - D.C. Filter Chokes - (153 - 159 Series)
Hammond Mfg. - D.C. Filter Chokes - Enclosed & Potted Versions (193 Series)
Low Frequency (Inductor) Chokes On Triad Magnetics
Old 28th February 2016, 10:51 AM   #10
Default lundahl filament chokes
Hello,
In the past i had the a modified Hiraga 30 watt amp which used the chokes developped for another amp designed by the French team.
The french choke was 200mH, 2,5A and 0,8 ohm. I dasked the shop in Paris if i could use the choke in my Hiraga and they said sure!
Now there are some lundahl filament chokes that could be used in some solid state amp designs but nobody seems to try it!!
With the lundahl which has 2 windings you only need one choke. Per Lundahl did assure me if the current in the negative and positive lead are equal current the Lundahl can be used.
Because the ac voltage across the choke is low the current going through the choke can be much higher. See the following link.
Lundahl Plate chokes, Lundhal Anodendrossel
There is one more '' dealer '' in Germany who sells Lundahl chokes with reduced mH but extra current capability if i am right.
People should not worry to much about ohmic value of the choke.
So far i only see people using very low mH chokes. I would like to encourage people to try a filament choke in their Pass or other class A amps.
Greetings, Edward
Hammond 159zl as clc chokeHide this!Advertise here!
usign redundanct power transformer as CLC choke muddasirwaheedmalik Power Supplies 19 22nd November 2012 04:07 PM
choke positioning in CLC supply sekess Power Supplies 2 4th November 2009 02:24 AM
Asking for choke value or calculation for CLC filter Groundloops Power Supplies 5 15th September 2009 07:51 PM
Aleph P 1.7 pwr. supply choke clc Shaun Perez 2 Pass Labs 5 9th November 2005 01:17 AM
Hammond 159ZL as inductors in a Pi-filter? mats73 Pass Labs 7 8th April 2003 06:30 AM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
Copyright ©1999-2020 diyAudio
