Aleph-X builder's thread.
Old 29th September 2019, 05:32 PM   #2701
rysiu1267 is online now rysiu1267
I want to build aleph x
Voltage 21 v dc 800W monoblock Transformer power per channel I already have.
using 4x irfp150 what bias current can I use and what power will I get?
Which company should I use irfp? Vishay will be good?
Old 29th September 2019, 05:36 PM   #2702
Zen Mod is offline Zen Mod  Serbia
Official Court Jester
Zen Mod's Avatar
clarify - what 800W?
my Papa is smarter than your Nelson !
clean thread; Cook Book;PSM LS Cook Book;Baby DiyA ;Mighty ZM's Bloggg;Papatreasure;Papa... by Mighty ZM
Old 29th September 2019, 05:41 PM   #2703
Old 29th September 2019, 05:54 PM   #2704
Zen Mod's Avatar
clarify , what exact AC voltage (full specs - 2x ??Vac , or ??VacCT (center tapped))
even before that , say that 800VA is usually covering up to 250-300W of steady power consumption/dissipation
for that , you need much more outputs per channel , or your amp will be either current starved , or non-reliable
see Babelfish XJ , or JX …….. or whatever (Aleph X servo for Greedy Boyz) for more info
Old 29th September 2019, 06:07 PM   #2705
2x18V transformer ac voltage.
Instead of 8 x irfp240 I wanted to use 4x irfp150. Without exact pairing if possible.
Old 29th September 2019, 06:19 PM   #2706
Zen Mod's Avatar
18Vac per rail will result in something as 22V5dc , loaded
say that you have 250W of dissipation per channel , 4 quadrants of outputs ........ that's 62W5 per quadrant , which calls for no less than 2 mosfets per quadrant , to keep dissipation per device in sane bracket
you must have matched all per quadrant , so matched pairs
though , it demand some thorough planning - what value of source resistors and few other details , to ensure that amp is stable dynamically and temperature-wise
now when you know numbers , try looking for example someone already built
Eric's web page about his Aleph X adventures is good place to start
Old 4th October 2019, 02:20 AM   #2707
Eric is offline Eric  United States
Eric's Avatar
Link is in my signature... Some of the images are a bit fuzzy, but all of the text is there for planning an Aleph-X amp. The nice thing about this design is you can easily customize it to suit your specific needs: optimize for 8 ohm load, optimize for 4 ohm load, adjust for specific power output figure.
An 800VA transformer can net you about 125w into either 4R or 8R loads. You'll need to have LOTS of heat sinking for each channel.
DIY Theater, Aleph-X Amps, LDR based BA-3 pre, B1 Korg, Pearl II, modified SL-1200 TT, F4, M2, Aleph-J, MoFo, a40, ACAs, FHXL & TB 1772 speakers
Old 3rd December 2019, 01:29 PM   #2708
Villaw is offline Villaw  Cyprus
Default PCBs
Any 100w AX pcbs left anywhere? I'd rather avoid having someone design them for me as I dont have the time.
Nick
Old 3rd December 2019, 01:53 PM   #2709
Eric's Avatar
There are many out there still! I bet you'll turn up a pair shortly...
Old 3rd December 2019, 01:55 PM   #2710
trouble is that one can only source the 40w version total 8 IRFPs per channel. I need the higher power version.
Nick
Aleph-X builder's thread.Hide this!Advertise here!
Copyright ©1999-2019 diyAudio
