Aleph-X builder's thread.
Old 2nd August 2018, 10:58 AM   #2681
Zen Mod is offline Zen Mod  Serbia
Official Court Jester
Zen Mod's Avatar
best are the ones having least amount of interelectrode capacitance .... but cheapest ones are even better
it really depends of your intention - how many you want to put in each quadrant
if you prefer small number , IRFP150 is best choice , as I wrote
with little luck , you don't even need to match them , if staying with just one per quadrant
however , if you intend to feed speakers with less than nice modul of impedance , there is no replacement for displacement , as our friends from hot rod department use to say
X is bridged amp , each half seeing just half of load ..... so number of outputs is what is giving you muscles
my Papa is smarter than your Nelson !
clean thread; Cook Book;PSM LS Cook Book;Baby DiyA ;Mighty ZM's Bloggg;Papatreasure;Papa... by Mighty ZM
Old 2nd August 2018, 01:16 PM   #2682
Flushing Shadow is offline Flushing Shadow  Netherlands
Flushing Shadow's Avatar
So to double the output, the number of fet's quadruples?
Old 2nd August 2018, 02:12 PM   #2683
Zen Mod's Avatar
dunno
4 quadrants ......
go figure
Old 2nd August 2018, 02:49 PM   #2684
Originally Posted by Zen Mod View Post
dunno
4 quadrants ......
go figure
Duhu :-)
Old 5th August 2018, 01:41 AM   #2685
metalman is offline metalman  Canada
metalman's Avatar
no less than 2 mosfets per quadrant , so 8 per channel
only in case that you use IRFP150 , practically 2pcs of IRFP240 in one case , you can go with 1 per quadrant
Disagree. My Aleph-X monoblocks use 4 IRFP044’s with 15V rails and 2.5A bias per device, and have been in heavy use for around 10 years. It’s a matter of heat sinking. Remember, Nelson Pass tells us that Mosfets get more linear in response with higher bias right up until the magic smoke is released. The downside is that less devices results in lower damping factor, but with the aleph current source creating a sort of negative output impedance effect, the impact of the fewer devices is somewhat mitigated.
For guidance on where the boundaries are for per device power dissipation see Transistor Dissipation and Turbo Projects
Terry
Darn career gets in the way of my audio addiction!
Old 5th August 2018, 02:59 AM   #2686
Zen Mod's Avatar
oh yeah Terry ........ you can go whichever way you want , with enough experience ..... but you don't want a novice to burn his fingers on first proper amp project ?
besides , comparing IRFP044 with IRFP240 is ........ something as cheating
Old 8th August 2018, 03:16 AM   #2687
Eric is offline Eric  United States
Eric's Avatar
Originally Posted by Flushing Shadow View Post
I’m looking for the BOM for the original pcb, can’t seem to find any info in the wiki or am i just looking in the wrong corner?
Even when I'm not on vacation, Zen usually beats me to the punch. Have a look at my webpage for the Aleph-X amp - link is in my signature. I have the BOM for original 15v version as well as for the higher powered 22v version. Just about all of the information you need is there, though it's a little messy as the page evolved over a period of 7-10 years...
I also have a copy of the original wiki for this amp on my web page.
My DIY Basement Theater, Aleph-X Amps, Avro Open Baffle Speakers, LDR based BA-3 pre, Pearl II, highly modded Technics SL-1200, F4, M2, Aleph-J, MoFo, a40, several ACAs, FHXL, Tang Band 1772 bass-reflex
Old 8th August 2018, 10:43 AM   #2688
Thanks! I allready found your page and i am soaking up the info!
Old 10th October 2018, 02:41 PM   #2689
vdi_nenna is offline vdi_nenna  United States
vdi_nenna's Avatar
Aleph-X builder's thread. Send a message via Yahoo to vdi_nenna
Default IRF9610 Alternatives
Are there any alternatives to the IRF9610 mosfets? I didn't see much reference to updates or alternatives in this thread, unless I missed it.
A couple of the alephs received a face-lift in the input stage, or at least "better" mosfets were substituted. Can those articles be referenced to update the AX frontend?
Thanks,
Vince
I build, therefore I am.
Old 10th October 2018, 03:00 PM   #2690
Zen Mod's Avatar
besides reading Papa's Aleph reloaded thread (same applies here) , you can take a look at Babelfish XJ , or JX …….. or whatever | Zen Mod Blog
Aleph-X builder's thread.Hide this!Advertise here!
Copyright ©1999-2019 diyAudio
