Aleph-X builder's thread.
Old 24th May 2012, 04:45 PM   #2181
oneplustwo is offline oneplustwo  United States
oneplustwo's Avatar
I have 16 (per channel.) Sounds like four would be the way to go. I might be able to parallel two on top and two on bottom of the board. Any comments on the source resistance? I also noticed the input (AC) coupling is different compared to my schematic. Is that a requirement based on a JFET vs MOSFET front end?
My Projects
Old 25th May 2012, 04:42 AM   #2182
oneplustwo's Avatar
What is the limiting factor on the jfets? It looks like the 74s are rated for twice as much power dissipation at 400mW than the 109s. As such, perhaps using two vs four might be ok?
My Projects
Old 25th May 2012, 08:02 AM   #2183
jacco vermeulen is offline jacco vermeulen  Netherlands
jacco vermeulen's Avatar
Send a message via Yahoo to jacco vermeulen
If you have J74's with higher Idss.
Old 25th May 2012, 08:03 AM   #2184
wuffwaff is offline wuffwaff  Netherlands
wuffwaff's Avatar
the limiting factor is the current they can deliver. With only 10mA total bias this is only half the current the standard 9610´s can deliver.
This will cause bandwith limiting.
There are a few more reasons why two pairs is better. You can find them in the thread I posted somewhere above.
William
een ooievaar is geen konijn want zijn oren zijn te klein!
Old 25th May 2012, 10:14 PM   #2185
oneplustwo's Avatar
If I can get two pairs, would I stick with the 15R source resistors as well or eliminate as Graeme has done?
My Projects
Old 25th May 2012, 10:42 PM   #2186
wuffwaff's Avatar
I only used the source resistors (in form of a pot) to get my relative DC offset low enough. I had not enough 2SJ74 to find good enough matches.
William
Old 25th May 2012, 10:50 PM   #2187
gl is offline gl  United States
I removed the 15 ohm resistors years ago. I consider them unnecessary.
Graeme
Old 26th May 2012, 12:46 AM   #2188
oneplustwo's Avatar
Mine are matched with with 0.5mA. I think I will try the MOSFETS from Graeme (thanks again Graeme) since I know that will work fine and then consider upgrading to JFETs later. Besides, that will give me a chance to hear for myself what the difference is.
Plus, tinkering is fun!
My Projects
Old 30th May 2012, 07:14 AM   #2189
mace_be is offline mace_be  Belgium
Does anyone have alpeh-X boards for sale ?
I have bought a guys big monoblock DIY Alpeh X amps, but his pcb is a little confusing, it goes not use the component numbers on the original schematic and the track width is somewhat narrow. it's easier for me to do debugging when i can easily correlate the components on the pcb with the schematic.
Old 7th June 2012, 04:16 PM   #2190
jeekee is offline jeekee
Default PCB's?
Hi there,
I am also looking for a couple of PCB's for the "low" powered version of Grey!
Anybody able to help me out here?
Cheers!
Aleph-X builder's thread.Hide this!Advertise here!
Copyright ©1999-2019 diyAudio
