Making the Nelson pass crossovers warmer
Old 9th November 2015, 10:54 PM   #1
Paulytwo is offline Paulytwo  Australia
Default Making Nelson Pass Crossovers (l300) warmer?
Hi all,
I posted the below on another forum and it was suggested that I may actually 'contact the creator' here :-) Any suggestions would be appreciated thankyou.
A link to that post, with an attachment that runs you through my build is here http://www.audioheritage.org/vbullet...ossover-please
G'day All,
I've completed my Nelson Pass crossovers and installed them into the speakers with pleasing results.
I do however have a little issue with the 'warmth' of the sound (please dont start having a go at me for describing sound with words... there just isnt another way in this post :-p), which got me to wondering...
The Nelson pass design for the midrange driver specified an 8 Ohm Lpad rather than the JBL standard crossovers 16 Ohm. (3133 equiv. circuit).
Also - I'm unsure of the impedence of the components in these boxes as they've been around quite a while... How can I simply find the impedence of each driver?... Can I just look at their resistance and estimate from there?
I'd really like to confirm that my impedences are wrong because that would explain the sound to me, and give me a path to resolve the issue.
Oh - also - What should the impedences of each driver using the Nelson Pass crossover be?
Thanks for listening - Any advice appreciated (outside of 'Go Active') :-) Thanks
Pauly
Old 10th November 2015, 02:11 AM   #2
Old'n'Cranky is offline Old'n'Cranky  Australia
Your new to JBL aren't you
All the info you require is on that very heritage site.
Search for the model numbers of the drivers you have.
Amazing the amount of info and JBL technical documents they have for free download.
Also search for L300 and 4333.
HINT - Look at the drivers and crossovers used for both EARLY and LATE productions of both.
Old 10th November 2015, 02:19 AM   #3
G'day ONC
Yes - Only been buying and working with them for 40 years. I was referred to this site from that one.
Thanks.
Paulytwo
Old 10th November 2015, 08:34 PM   #4
2 picoDumbs is offline 2 picoDumbs  Australia
2 picoDumbs's Avatar
Link not working.
Can you post schematic.
"If you leave this point unattached to some circuitry, an ideal constant current source will emit a small lightning bolt which will travel until it connects to something." Nelson Pass
Old 10th November 2015, 10:48 PM   #5
Hi Pico,
Thanks for looking - Here's the circuit diagram -
Thanks again
Pauly
Originally Posted by 2 picoDumbs View Post
Link not working.
Old 11th November 2015, 07:39 AM   #6
I haven't forgot ya Pauly. I will look at the crossover properly tonight.
Are you open to the possibility of building an amp?
Old 11th November 2015, 07:56 AM   #7
G'day Pico,
Thanks!
No - I wont be building an amp! Here in Australia, you could buy a really nice amplifier for what it would cost to build one. Also, the amp I'm using to drive them (400W Mosfet) is a pretty good amplifier - certainly can sound wonderful.
Thanks again - I look forward to your comments.
Pauly
Old 11th November 2015, 09:21 AM   #8
Hi again Pico
I have been researching a bit more and thought I should mention that I have used foil inductors for L1 and L3 (the series inductors) -
The Values and DC resistance of each are;
L1
2.2MH & 0.59 Ohms
L3
0.18MH & 0.5 Ohms
Hope that helps or makes a difference
Thanks again
Paulytwo
Old 11th November 2015, 09:30 AM   #9
Do you have frequency response measurements for your drivers?
Old 11th November 2015, 09:41 AM   #10
Drivers are mostly resistive so often measuring resistance is good enough to tell the difference between 8 Ohms and 16 Ohms.
You can also look for the specifications on the manufacturers data sheets?
Making the Nelson pass crossovers warmerHide this!Advertise here!
Nelson Pass Professor smith Pass Labs 79 1st August 2010 07:30 PM
My thanks to Nelson Pass SY Everything Else 7 19th May 2004 02:47 AM
My opinion on Pass Labs and Mr. Pass (Nelson) himself b_online Pass Labs 11 21st May 2003 01:39 AM
Nelson Pass macka Pass Labs 6 31st May 2002 01:52 AM
