Official M2 schematic
Official M2 schematic Please consider donating to help us continue to serve you.
Old 2nd September 2019, 07:07 PM   #3361
Zen Mod is offline Zen Mod  Serbia
Official Court Jester
Zen Mod's Avatar
as I see it - voltages you measured around JFets are ok
one thing - if you don't have chassis yet - did you heatsinked output mosfets for these first tests?????
my Papa is smarter than your Nelson !
clean thread; Cook Book;PSM LS Cook Book;Baby DiyA ;Mighty ZM's Bloggg;Papatreasure;Papa...© by Mighty ZM
Old 2nd September 2019, 07:15 PM   #3362
darrr is offline darrr  Poland
I used a replacement heatsink. Too small to work but sufficient to run for measurement. When I turned off the mosfet temperature it was around 100 ° CIMG_20190902_172323.jpg
Old 2nd September 2019, 07:21 PM   #3363
Zen Mod's Avatar
good
and I thought that I'm sole dumb kwayzee lucky bstrd around
leave it in cardbox , please , while waiting for proper chassis
Old 2nd September 2019, 07:28 PM   #3364
Good advice Official M2 schematic . Chassis and pair of jfets....
Old 2nd December 2019, 07:49 PM   #3365
metallicus69 is offline metallicus69  Netherlands
I have built only the final stages, 2 stages per channel, to be driven by a differential Aikido tube stage. I was always looking for a Vertical stage in place of the Laterals used at Moskido. And this seems to be a great solution.
My problem is that the static current through each MOSfet is around 1,15A at 24V supplies and 1,3A at 30V supplies. The offset is quite stable after warming up to 55-58C and easily set after changing the P1 to 10kohms and R7 to 51kOhms.
Decreasing R13 and R14 to 0,33 would bring the current over 2,2 A, so probably I should rather increase R11.
The question is: should I aim to increase it more? Is it 1,2A enough considering a dual stage (so 2,4A in total per channel) driving 8Ohm speakers? Or will it leave the A class too early?
Thanks for your time to read my post and applologies if this is not a good thread for my questions!
Old 2nd December 2019, 08:22 PM   #3366
Zen Mod's Avatar
if you're content with sound , leave it
for gradual increase of Iq , try increasing resistor in series with opto-led
sensibly,please
Old 3rd December 2019, 03:28 AM   #3367
aljordan is offline aljordan  United States
Is there an ideal voltage for the power supply to be delivering to the M2 boards under load? My power supply is delivering ~ 21.2 volts under load, and my heat syncs are not very warm, so I am wondering if I should do a little work on the power supply.
Old 3rd December 2019, 04:15 AM   #3368
Extreme_Boky is offline Extreme_Boky
The transformer specifications should say 2 X 20V AC at the secondaries... to begin with.
Some transformer manufacturers will let you specify the secondary voltage in 1V increments, so 2 x 21V AC might be perfect.
The voltage sag will also depend on the transformer VA rating; the higher the VA, the lesser of a sag.
I use 230V-specified transformers, at 2 X 20V AC, connected to 240V mains.... so that gives me around 2 X 21 V AC or so.
Of course, the quiescent current per each output transistor will also influence the whole thing.
It is also important to remember that mains voltage could vary substantially, depending on your electricity provider/distribution network. Just another factor to take into consideration.
There's a bit of a voltage drop across the thermistor as well.
Also, the power dissipation is directly proportional to (an increase) of supply voltage... so with 5U / cooler climates, it ain't gonna be a problem.
Old 3rd December 2019, 08:05 AM   #3369
sensibly,please
Thanks!
No extensive sound auditions yet, I have to build the solid state protection relay first and connect everything in the boxes; at the moment I am just testing the static and thermal parameters, to be sure they will survive.
I did some audition with them though directly from a headphone output to the power buffer and the sound seemed ok in my modest test speakers.
As all is done p2p It would be easier to replace the 0R47 resistors with 0R33 but I don't feel like it will be a good idea, so I will probably leave it as it is.
Old 3rd December 2019, 04:43 PM   #3370
I used a 2 x 18 volt 300 VA transformer. I thought the first watt power supply specified 18 volt. Does the M2 specify 20 volt?
Official M2 schematicHide this!Advertise here!
First Watt M2 Kovax Pass Labs 154 13th February 2014 06:20 PM
JBL m2 ! Ahmad_tbp Multi-Way 0 7th February 2013 02:14 PM
First Watt M2 chrismercurio Pass Labs 16 18th March 2012 02:53 PM
swans m2 blue934 Multi-Way 0 22nd May 2008 06:56 AM
Audio Note M2 regulator schematic drobert Tubes / Valves 1 10th November 2007 04:09 AM
Copyright ©1999-2019 diyAudio
