I am very curious on your opinion of the sound difference. I never built a F5 because of Nelson saying the F5 tends to be on the bright side and horns have a tendency to be bright already.
The attenuator system that I employ on my horm speakers are quite good and offer me a great tweak range no matter what amp I use ( see photo )
And I use 3
What I am looking for is more multilayer bass extension from this upgrade and I will report my findings as I progress
FR
I know its a little late now, but I found that by doubling the cap bank in the F5 from stock really helped with bass punch and extension.
IF you have a few caps lying around you can try that and see what happens.
Also, if you haven't taken out the protection circuit in the stock F5, do it.
My dual mono F-5 does not lack in the least with bass punch.
Russellc
These are different things.
If he means rich tonal character of the bass then I think he will get that with the F6.
The ACA is syrupy rich in layering and tonal character but you need the right speakers, the F6 is a good compromise for most speakers.
I have a gut feeling I can achieve the same effect with F5, just need to test out the idea. I'm working on it now.
That means I'm building the chassis (drilling + tapping holes etc).I'm working on it now.
Hi Fullrange, does your autoformer in the crossover attenuates just the super treble or the "midrange plus super treble- horns"?
stefan
Hi Stefan
The crossovers have two seperate attenuators
One for the tweeter this one is a PCB based attenuator db steps are 0, 3, 5, 7, 9
One for the midrange this one is a double wound auto former with 15 wire taps X 1 db steps
Cheers
FR
I am in a fortunate position of having very sensitive speakers that have that perfect synergy with the room they are in
It's difficult to fault them and I love the pitch black background of the F5
What I'm looking for with the F5 to F 6 upgrade is -
Finer 3D imaging
Delicate instrument separation
And multi layer bass extension
FR
For rich sound I think twisting P3 will help. If I'm not mistaken the F5 inherently is Third order harmonic dominant, adjusting P3 should be able to get the second order harmonic dominant.
As far as instrument separation and 3D, I've found that the more transistors you put it the more those two characters come out. The F5 Turbo gives you much more of that.
It gets you some of the way but I think there is a better way of doing it. At least my ideas work in simulation. I'll need to build it to be certain.For rich sound I think twisting P3 will help. If I'm not mistaken the F5 inherently is Third order harmonic dominant, adjusting P3 should be able to get the second order harmonic dominant.
Finer 3D imaging
FR
I haven't built F6 yet but I have built F5 and ACA, my gut says F6 should sit right between the two. You will gain some of what you are chasing but possibly lose some of what you already like with F5 (depends on what you like)
I can't really give any definitive advice until I've completed F6.
An F4 may even be the best option with your speakers or possibly a "modified" ACA. None of the amps are bad so you can't go wrong with any of them.
The only certain advice I'd give is to slowly go through and build all of them. If you haven't built one yet a pure single ended design should be on your build list just for comparison.
A quick update
The full F6 kit from the DIY shop has arrived
And the matched IRFP240 FETs have also arrived ( Thanks Hannes ) haven't seen so close matching in a long time
The order has also been placed for all parts required from 4 sources
Will post a brand list and why a particular part / brand / model was chosen when time permits
While I await delivery I got my hands busy and I made a set of 4 transistor washers
Material is 2 mm alloy
Shape is square and made to overlap the transistor
A small steel washer will also be used under the cap screw as well when the time comes to fit them to the heatsink
I like using these instead. Serve as a heatsink as well.
507302B00000G Aavid Thermalloy | HS115-ND | DigiKey
Did not know such a product existed thanks for the recommendation
@ PJN
Thanks for your input I have a gut feeling that with the F6 upgrade I will achieve my objective
FR
Update
This F5 to F6 upgrade has had a lot of thought go into it, however I have to thank the community for a lot of good ideas
This build will be to the latest ZenMod spec modification
Parts are trickling in slowly
Will also order those or similar bespoke transistor washers recommended above
Parts list and brands I have settled for is based on the items musical credo and fair value
Trim pots are 21 turn Bourns
Latest zm change with a few fine touches are
Z1,2 6.2v 1% 1/2w vishay
Elna Silmic RFS Series 2
1000uf 35volt
R1 0.56ohm 5W Mills non inductive wire wound
R2 0.47ohm 5W Mills non inductive wire wound
R3 100ohm 5W Mills non inductive wire wound
R4 18.2ohm 1/4w vishay/dale rn60
R5 1K 0.4w Charcroft Z-Foil Resistor
R6 47K 0.33w caddock tf020
R7,8,3.3k 1/2w vishay/dale cmf60
R9,10 10K 1/2w vishay/dale cmf60
R11,12 110ohm 1/2w vishay/dale cmf60
R13 Not used
FR
1000uf 35volt
R13 Not used
FR
- Upgrade F5 to F6
