F6 Illustrated Build Guide
Old 23rd May 2020, 09:40 AM   #1981
rollingtube is offline rollingtube  Germany
Hi James, the washers that you see in my pics are actually from the back panel parts kit from the diyaudiostore.
I wouldn‘t overengineer this, I think I saw similar simple washers (that‘s what they are) in one of the hardware section of a local home improvement store recently. If the store and the HW section is large enough, then they should also have stock of such unusual washer sizes.
Old 23rd May 2020, 09:59 AM   #1982
ColinA123 is offline ColinA123  United Kingdom
Those are "penny washers"
Like these. A2 Stainless Steel Penny Repair Flat Washers M3 M4 M5 M6 M8 M10 M12 M14 M16 M20 | eBay
Old 23rd May 2020, 01:35 PM   #1983
jameshillj is offline jameshillj  Australia
Thanks guys, much appreciated, especially finding them on eBay! And yes, I do tend to get a bit 'anal' about some of the details - it's a 'sort-of' challenge, or a puzzle! (I think there's a name for people like me!)
I did find a couple of different types of spring tension washers suitable for an M3 screw on the net (fitted between the screw head and the large 'penny washers') and am a bit undecided about the pressure to apply to the transistors - there seems to be a range between 2.5lbs and 7lbs - I've only looked at McMasters Carr and the MSC company - quite a range.
The transistor clips I've used apply are specified at 60N (about 10lbs) but I think it's a lot less in practice.
Working on Salas's L-Adapter to drive the F6 amp, biased to about 1.7A - going a bit overboard but ...
Old 23rd May 2020, 01:46 PM   #1984
TungstenAudio is offline TungstenAudio  United States
Something else to consider is using a torque screwdriver to get reliable and consistent torque on the M3 screws which attach the Mosfets to the heat sink. They aren't cheap, but are a good investment.
Old 23rd May 2020, 02:40 PM   #1985
But what torque sounds best?
Old 23rd May 2020, 07:59 PM   #1986
Yaho is offline Yaho  United States
Something I've never considered. For tubes, I just have to push them in tight and wiggle a little. What would be an ideal torque?
Old 23rd May 2020, 09:00 PM   #1987
I use 8 in-lb mounting torque. Max is usually 10 in-lb. The datasheet will have this in the Maximum Ratings section.
Old 23rd May 2020, 11:13 PM   #1988
And the date sheet says, Mounting 6-32 or M3 screw Torque 10 lb
I had no idea. I learned a new thing. Thanks so much!
Old 25th May 2020, 03:43 PM   #1989
chede is online now chede  Germany
... fascinated by amps
chede's Avatar
For large washers, you can also search for "fender washers" ...
For securing the bolts, I usually stick with split washers nowadays ... though, the best and proper thingies to use would be Belleville washers.
Best regards,
Claas
Old 25th May 2020, 05:25 PM   #1990
Thanks James and everyone - that pretty much gives a "ball park" tension range - some of the cheaper torque screwdrivers start about the 5 inch lb range.
I found some of the 3mm "penny washers" (thanks Colin) and the Belleville 'triple wave' washers seems a good way of doing things if there's not enough space for the clips.
F6 Illustrated Build GuideHide this!Advertise here!
BA-3 Amplifier illustrated build guide 6L6 Pass Labs 323 Yesterday 02:58 PM
Aleph J illustrated build guide 6L6 Pass Labs 5254 3rd July 2020 02:47 AM
F5Turbo Illustrated Build Guide 6L6 Pass Labs 598 2nd July 2020 10:30 PM
diyAudio Power Supply Circuit Board v3 illustrated build guide 6L6 Power Supplies 1299 29th June 2020 12:45 AM
ACA illustrated build guide 6L6 Pass Labs 169 16th June 2020 03:12 PM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
Copyright ©1999-2020 diyAudio
