F6 Illustrated Build Guide
Old 12th June 2019, 05:53 PM   #1321
wdavis009 is online now wdavis009  United States
Originally Posted by chatziva View Post
Very nice! Did you wire it as a dual mono psu?
Yes, it has a dual mono power supply.
Old 13th June 2019, 05:47 AM   #1322
mlwebb is online now mlwebb  United States
Default Another first time F6
Hi Folks. I've been stopping by here occasionally for a decade, thinking, I ought to try building an amp sometime, finally gave it a go.
My case design is a little idiosyncratic - the back is blank, so it can go up against a wall, or on a shelf. The front will get a nice piece of wood, plain, and the top will be 3/8 glass, with ground edges, set up an 1/8" above the sides. The edges of the glass lighting up from the led's inside will serve as my power light.
I have a plan to add forced air if needed. I put the power inlet/switch up towards the front, to reach it easier, and the outputs on the back sides.
I used 6.9v zener (LM329)-3.3k R7,8; Jfets from punkydawgs, and VS-HFA25TB60-M3 Hexfred's for the rectifiers. Transformer is an Antek 3218 (300Va, dual 18v)
Please look the attached over and let me know if I have made any rookie mistakes, etc before I start it up. ( I built a bulb tester, and plan to unhook each amp side, test the psu, then one side at a time. I have the zeners turned down. The amp guides were great, but pics of the diyaudio psu rectifier boards wired up are a little shy (I found one) - so let me know if I have it right. Thank you to NP and all here.
Michael
Old 13th June 2019, 06:41 AM   #1323
ColinA123 is offline ColinA123  United Kingdom
Hi, looks interesting.
Just a heads up, on mine the adjustment pots worked backwards.
Something to watch for if bias starts to rise when switched on.
Old Today, 01:07 PM   #1324
Alex Cazanescu is offline Alex Cazanescu
Hello to everybody!
I just finished my amp today ,solving the issues I had after a wrong bias :-)...and I have to say that I`m very happy and surprised about the sound.It is indeed amazing.I like it a lot! Many thanks to Diyaudio for that and especially to Mr. Nelson Pass.
Though ,there is one single thing I would like to improve , if possible.I have the feeling the bass is a bit shy .Is it possible to add more weight to the bass somehow?
The bias was set to 0.51 V ( the mosfet second pin 62-63 degr C).
I have used 5.8 zenners and 3.3K resistors.
Old Today, 01:24 PM   #1325
Zen Mod is offline Zen Mod  Serbia
Official Court Jester
Zen Mod's Avatar
give it some time , then judge the sound
pull up those mains NTCs , away from base plate
tell us more about rest of your setup , so we can comment where exactly to look for more bassssssssssssssssssssss
my Papa is smarter than your Nelson !
clean thread; Cook Book;PSM LS Cook Book;Baby DiyA ;Mighty ZM's Bloggg;Papatreasure;Papa... by Mighty ZM
F6 Illustrated Build GuideHide this!Advertise here!
Aleph J illustrated build guide 6L6 Pass Labs 3663 Yesterday 11:20 PM
diyAudio Power Supply Circuit Board v3 illustrated build guide 6L6 Power Supplies 882 Yesterday 07:26 AM
F5Turbo Illustrated Build Guide 6L6 Pass Labs 564 16th May 2019 02:25 PM
BA-3 Amplifier illustrated build guide 6L6 Pass Labs 224 11th May 2019 06:40 PM
ACA illustrated build guide 6L6 Pass Labs 157 1st February 2019 01:02 AM
Copyright ©1999-2019 diyAudio
