Home | Forums | Rules | Articles | diyAudio Store | Blogs | Gallery | Wiki | Register | Donations | FAQ | Calendar | Mark Forums Read |
Pass Labs This forum is dedicated to Pass Labs discussion. |
Thread Tools |
#2001 |
Thanks Alex and sorry for being so pushy...
#2002 |
No problem, I can understand that you get impatient.
#2003 |
Well all the past years in the Christmas period I visited my family members and all that kind of stuff you do in the period which mainly is socializing, I guess you all know and did the same.
Since this is the first year when everything will be closed and the relatives will not be so happy to see you at their door I planned to go ahead and do a bit of soldering for the preamp just to forget about the period which we go through. This is the reason which made me to be a bit pushy and impatient, hope you understand me and accept my apologies. |
#2004 |
They are here...
I can't test the second encoder because the optical encoder is still in the hands of ups. They blame snow for the delay ... Go figure. As soon as I get them I can test my whole contraption and then... If someone needed i can give Gerber's for both the adapters and the ring light. I trust stone for the functional test of the second encoder.. i didn't see that delay coming. So on that matter I have no feedback. Other than that... Everything else seems to run pretty smoothly.20201202_135744.jpg |
#2005 |
I'm in trouble
#2006 |
#2007 |
I have no received everything.
I will try to sort everything this WE. I will keep you updated ![]() |
#2008 |
Good luck
#2009 |
thanks, I almost finished sorting and preparing the PSU parts yesterday evening.
I just discovered that I have 3 missing refs. they should be delivered next week (mouser sent them directly from the US) |
#2010 |
For those who will use the PSU substitute, 2 things for now.
1- Be sure that you have the Hammond transformers pins straight, it is very tight when you put those in the PCB holes. Looks like the pins are a little bit bigger than in the datasheet. 2- If you use J113 instead of PF5102 Jfet, check the IDDS of each and adapt the signal resistor value of each (R4 R7 R8) see:Salas SSLV1.3 UltraBiB shunt regulator Also for the snubber parts, i will find the best value for the Hammond Transformer we use with my Quasimodo Board and will post the results.
Every DIYer need Balanced-Unbalanced Audio Input Selector Module |
Thread Tools | |
Thread | Thread Starter | Forum | Replies | Last Post |
FS. GB UP/UGS All Inclusive PCBs | mj777 | Swap Meet | 27 | 18th December 2018 09:31 AM |
GB UP/UGS All Inclusive PCBs | Faame | Group Buys | 12 | 15th August 2017 03:10 AM |
GB: UP amp and UGS preamplifier | Siberia | Group Buys | 1 | 26th August 2011 01:43 PM |
GB PCB UGS "all inclusive" launched (until 2008/11/23) | solalfrance | Group Buys | 7 | 5th January 2009 12:58 AM |
New GB PCB UGS all inclusive | solalfrance | Pass Labs | 3 | 9th November 2008 04:41 PM |
New To Site? | Need Help? |
