Sony VFET Amplifier Part 2
Old 27th September 2018, 07:20 PM   #3641
Nelson Pass is offline Nelson Pass  United States
The one and only
Nelson Pass's Avatar
I have the 2SK60 and 2SJ18's, and I think the 16's should work also.
Old 28th September 2018, 09:59 AM   #3642
Chul is online now Chul  South Korea
Please tell me Nelson, are four 2SK60s in parallel are comparable to one Pass-SIT, or worthy of trying in any circuit including DEFiSIT?
Old 28th September 2018, 06:31 PM   #3643
The one and only
One 2SK60 is roughly a single SIT-1 transistor. No need to parallel.
Old 29th September 2018, 03:50 AM   #3644
A Zen answer to an ignorant question...
Old 9th November 2018, 05:22 AM   #3645
flocchini is online now flocchini  United States
Default Put...Put...Put
I just switched from 89dB speakers to 94dB speakers.
Using TeaBag VFET2 boards with Botte suggested changes
With CLC PSU using 25V transformer: .
If I put my ear very close to the speakers I hear a put.. put.. put. Frequency is about a beat per second. Same for both speakers. At listening position can't hear the put put put - just great sound
Repeated using 22V transformers - same thing
Switched to a different CLC PSU using 18V transformer - no put puts
Thoughts anyone???
Much appreciated and thanks
Bob
Old 9th November 2018, 06:46 AM   #3646
Zen Mod is online now Zen Mod  Serbia
Official Court Jester
Zen Mod's Avatar
from yeah putput to nay putput , you changed either wiring ......... or more likely - you changed damaged cap
my Papa is smarter than your Nelson !
clean thread; Cook Book;PSM LS Cook Book;Baby DiyA ;Mighty ZM's Bloggg;Papatreasure;Papa...© by Mighty ZM
Old 9th November 2018, 02:27 PM   #3647
Russellc is offline Russellc  United States
Originally Posted by Blk Dynamite View Post
Just curious if anyone knows of the UMS compatible TO3 mounting brackets will ever be in stock again?
Is this still the case? (That these brackets will return to store) I notice they are no longer pictured...EEEK!
Russellc
Pass B-1 preamp, Pass BA3 preamp, Pass F-5 Amp, Pass F-6 Amp, Pass BA-3 Amp, Pass M-2 amp, Pass Aleph J amp, Pass Pearl 2 Phono pre Tekton Enzo, Altec A7, Econowave JBL 2235H & B&C CD
Old 9th November 2018, 02:39 PM   #3648
ZM
In the 22V and 25V setups I also changed the cap bank - still the same
putt-putt
I'll check wiring today
Something with regulators ????
18VAC not enough to fire them up ????
It's irritating and hopefully doesn't damage the speakers
Thank you
Old 9th November 2018, 03:14 PM   #3649
Zen Mod's Avatar
aha
now you tells more ....
with PSU voltage - to have putput , try (temporary) "shorting" R20 (schm from post #11)
but!! "shorting" means not dead short (offset issue ) but just AC shorting with , say, 470uF cap , neg pole to gnd
idea is isolating FE from OS
if putput is gone , FE is culprit
is putput ( I like that worrrrrrrd!) is still there , OS is culprit
then we can go further
Old 9th November 2018, 04:32 PM   #3650
Again thank you ZM
Will do this during the weekend
Best
Bob
Sony VFET Amplifier Part 2Hide this!Advertise here!
Sony VFET Amps Nelson Pass Pass Labs 229 2nd January 2019 11:02 AM
PCBPCBs for Nelson Pass‘ CSX1 SONY VFET amplifier permaneder Group Buys 430 25th August 2018 12:09 PM
Sony Vfet housing Solid State 26 26th January 2014 04:38 AM
Sony TA-N7B VFET Help!! gpdavis2 Solid State 16 24th October 2009 02:20 PM
Sony VFET...tragic... EchoWars Solid State 21 11th November 2006 12:40 PM
Copyright ©1999-2019 diyAudio
