Gyrator loaded Son of ZV9/F3
Old 29th August 2018, 09:42 AM   #211
maouna is offline maouna  Greece
I have already made a pcb for the previous schematic so i would like to give it a try but i dont have the specified part ,only BF245B!!!why you wouldnt recommend it??
Old 29th August 2018, 11:24 AM   #212
juma is offline juma  Serbia
juma's Avatar
Because the other one is better. The one from post #209 will work OK - use those BF245B that you have (Idss=8.8mA) without source resistor (R8,R17) or a very small one (10R) and adjust the value of R3,R21 so that you get half of the regulated power supply voltage at the MOSFET's drains (Q2,Q3).
Please don't use private messages for question related to audio projects. It defeats the purpose of the forum.
Old 22nd February 2019, 12:33 PM   #213
I am almost done with the preamp of post #1 but i have question.
I see a resistor on the mini PCB on which BF862 is soldered.Does this resistor connects to the gate of BF862?
Old 22nd February 2019, 01:06 PM   #214
For the psu section i am going to use a shunt psu posted by Juma, with 24Vac transformer (35V after rectification). the current source fet bf862 has to be changed to something with higher Vds than 35V.What do you suggest? I have 2SK170,BS170.
Old 22nd February 2019, 02:45 PM   #215
vdi_nenna is offline vdi_nenna  United States
vdi_nenna's Avatar
Is the BF861B a suitable replacement for the BF862? What about any of these other jfets at Mouser?
JFET N-Channel SMD/SMT RF JFET Transistors | Mouser
What's the ideal jfet Idss for the circuit in post #1?
I would like to build it like the original circuit.
Are there any changes to the circuit in post #1?
I want to drive an F4 and MoFo power followers.
Thanks,
Vince
I build, therefore I am.
Old 22nd February 2019, 02:53 PM   #216
vdi_nenna's Avatar
Is Idss of 14 ideal?
Old 23rd February 2019, 04:08 PM   #217
juma's Avatar
Originally Posted by maouna View Post
...Does this resistor connects to the gate of BF862?
It's a gate stopper. It doesn't make a difference here because R3 (22k) does that job already.
...bf862 has to be changed to something with higher Vds than 35V.What do you suggest? I have 2SK170,BS170.
2sk170 or 2sk246 (any grade will do).
BF861B with Idss >= 12mA will do OK.
Got no time to browse through all those datasheets but you should look for parts with high gm and linear transfer curve. Although, with some effort, many will work OK.
12-15mA
I don't remember - did many different stuff since then. Maybe you should search/browse through thread(s).
12-15mA
Old 23rd February 2019, 05:29 PM   #218
vdi_nenna's Avatar
Thank Juma.
Old 23rd February 2019, 06:08 PM   #219
Thanks for the suggestions.Juma,do you have any other shunt PSU like the one with TL431 but with 48V output and the same noise suppression results??.My load current will be max 22mA
Old 23rd February 2019, 07:02 PM   #220
If i want to put a coupling capacitor between input volume pot and R3,where should i connect the + of the 10u electrolytic capacitor?(i only have 10uF/50V electrolytic nichicon FW series)
Regarding the 470ohm gate stopper resistor,should i ommit it ithis case? i have already made space for the resistor in my small pcb.
Gyrator loaded Son of ZV9/F3Hide this!Advertise here!
L Loaded ZV9 Help??? flg Pass Labs 76 23rd December 2016 10:28 AM
cascoded gyrator loaded 6H9C to low idle. kees52 Tubes / Valves 11 29th December 2011 04:24 PM
F3 vs. ZV9 - the differences... HVfanatic Pass Labs 8 3rd June 2011 08:03 PM
Gyrator Loaded 12b4A: The Latest Version. SGregory Tubes / Valves 40 3rd January 2011 02:26 AM
First Watt F3 & ZV9 breguetphile Pass Labs 3 10th July 2006 10:53 PM
Copyright ©1999-2019 diyAudio
