About possible Babelfish J interest
Old 5th December 2018, 08:53 PM   #531
transcendent is offline transcendent
oh great, i only have two DVM haven't connected psu yet to amp pcbs and haven't measured it as well.
it's dual mono build, here's a test assemble to see how the wiring would go through...
Old 5th December 2018, 09:01 PM   #532
Zen Mod is offline Zen Mod  Serbia
Official Court Jester
Zen Mod's Avatar
make bulb tester , and test PSUs first
my Papa is smarter than your Nelson !
clean thread; Cook Book;PSM LS Cook Book;Baby DiyA ;Mighty ZM's Bloggg;Papatreasure;Papa... by Mighty ZM
Old 5th December 2018, 10:03 PM   #533
ok, got close to 25vdc, with 18vac secondaries from transformer sounds about right?
btw, how fast voltage should go down after disconecting mains?
Old 5th December 2018, 10:15 PM   #534
Zen Mod's Avatar
damn slow , if there is no load
take care to drain them off , before soldering to pcbs
Old 5th December 2018, 10:50 PM   #535
ok, will do! also, could you explain "shorted inputs"? i have rca terminal only.
Old 5th December 2018, 11:05 PM   #536
Zen Mod's Avatar
if you have just RCA input , be sure that you solder shortie ( piece of wire) between negative input and GND on pcb
shorted input means - take cheap RCA jack , solder shortie between GND and hot , and shove it in RCA in of amp
that's preventing crocodile getting in , if you leave input unguarded
Old 6th December 2018, 09:03 PM   #537
should i use wire as thick as possible between mosfet and amp pcb? planning to use 1.5mm
this is in case not connecting it directly to the board..
Old 6th December 2018, 09:21 PM   #538
Zen Mod's Avatar
D and S
Gate can be connected with tiny one
if wires longer than , say , 6 or 7cm , think about moving gate resistors to mosfet gates , series with wire (heatshrink )
then put shorties on pcbs , instead of gate resistors
Old 6th December 2018, 09:51 PM   #539
OK, good to know, but it should be fairly close.. ~4cm up to 5cm
About possible Babelfish J interestHide this!Advertise here!
Babelfish J2 , just one package for sale Zen Mod Swap Meet 6 22nd April 2015 02:59 PM
For interest M Gregg The Lounge 0 26th September 2014 09:50 PM
Just for interest.. M Gregg The Lounge 0 17th July 2013 08:56 PM
Babelfish J combos Zen Mod Swap Meet 0 18th June 2007 12:18 PM
Maybe of interest... Ropie Analogue Source 2 20th April 2004 07:18 PM
