About possible Babelfish J interest
Old 15th November 2018, 08:54 PM   #501
transcendent is offline transcendent
ZM, could you get these as well, 1st one most importantly...
Originally Posted by transcendent View Post
1) In case using only base PCB, I should only connect AD-AS, instead of N1-N2 right?
2) Is there a good reason placing transformers in front of the case and wiring through the bottom baseplate? Looks easier to have them in the back with less wiring.
Old 15th November 2018, 10:38 PM   #502
Zen Mod is offline Zen Mod  Serbia
Official Court Jester
Zen Mod's Avatar
ignore AD and AS
you can also ignore N1 and N2
or use either one to solder fat wire bridge
N1 and N2 are exactly for bridge , because when you're using multiple output pairs , there is significant current flowing through copper traces
while AD means All Drains (drain side of all mosfets in lower group) , and AS means All Sources (source side of all mosfets in upper group) , when using multiple outputs
with just one pair of outputs simply ignore these pads
I'm always routing (just) mains wires (going from IEC on back to xformers in front)bellow base plate ; that way base plate is also serving as shield for mains wires
when I'm using other case , without base plate , I'm always screening mains cable , going from IEC on back side to xformer in front
my Papa is smarter than your Nelson !
clean thread; Cook Book;PSM LS Cook Book;Baby DiyA ;Mighty ZM's Bloggg;Papatreasure;Papa... by Mighty ZM
About possible Babelfish J interestHide this!Advertise here!
Babelfish J2 , just one package for sale Zen Mod Swap Meet 6 22nd April 2015 02:59 PM
For interest M Gregg The Lounge 0 26th September 2014 09:50 PM
Just for interest.. M Gregg The Lounge 0 17th July 2013 08:56 PM
Babelfish J combos Zen Mod Swap Meet 0 18th June 2007 12:18 PM
Maybe of interest... Ropie Analogue Source 2 20th April 2004 07:18 PM
