About possible Babelfish J interest
Old 18th February 2018, 10:13 AM   #371
Zen Mod is online now Zen Mod  Serbia
Official Court Jester
Zen Mod's Avatar
150W/ch
well ....... install nice fat wirebridge on main pcb , on speaker route
think trice about gauge of wires ...... can't be sure in reference I can get from pictures, but they look tiny for amount of ambition .....
I hope , when you are talking about 38Vac/52Vdc , that you're talking about twice that ... (+/-)
will be back soon with figures
my Papa is smarter than your Nelson !
clean thread; Cook Book;PSM LS Cook Book;Baby DiyA ;Mighty ZM's Bloggg;Papatreasure;Papa...© by Mighty ZM
Old 18th February 2018, 10:21 AM   #372
Coasttocoast is offline Coasttocoast  United States
ZM thanks as always!
Using your references Thick = 14ga, Medium = 16/18 ga, Thin = 24ga
I don’t need 150wpc per se, what do you recommend for what I have?
Babelfish J as Aleph 2, McIntosh C2300, RAKK DAC Mark IV Extreme, Oppo UDP-203 DVD/CD, Custom SP10 MKII/SME 312s/Koetsu Urushi Black, Magna Mano streamer, Ekta Grande speakers, DIY 13" ScanSpeak sub's w/Hypex Fusion 501ís, Transparent Ultra cables.
Old 18th February 2018, 10:47 AM   #373
Zen Mod's Avatar
ref to sch in #315
increase R12 to 5K6 (normal metal film) , to save little piggy of poof
counting on fact that you're using source resistors of 0R27 .........
you'll end up with rails of aroundish 48V .......
to use everything of it , and still in full current envelope at 8R load , you'll need sum Iq aroundish 4A ....... that being 4A/6 per vertical pair
be sure that (R24+TP3) combo is giving you range of min 35K and upwards (start from MINIMAL value , which is giving you min Iq)
set Iq as 0A65 through vertical pair ( being 0A65 x 0R27 = 176mV across any of 0R27 resistors)
be sure to have sum value of sense resistors (those biggies parallel on main pcb ) as 0R27/12 ...... thumb of rule is value of source resistor divided with double number of vertical pairs
you'll end up with 2 x 48V x 4A of heat ... which is 384W , divided with 12 mosfets ...... means 32W each
give me heatsink arrangement pic again , just to calm my conscience
and , yes - this way you'll be close to 150W/8R ...... with plenty of greenies to frittfritt each month , for electron-bill
why don't you resort to some normal hobby , for geezers as we are - drugs , hookers, big cars .......
Old 18th February 2018, 10:58 AM   #374
Zen Mod's Avatar
well ...... if you compare these two pics :
these big honking bstrds (pictured on my messy bench) are cruising with 350W of heat per case ..... and that most probably just right for summer
taking that in account ..... I believe you must go even lower , to say 300W of heat max or even lower
which means that you must go even lower with sum value of (R24+TP3) ;
if you can't decreas Iq enough , or if you see that Iq is too much wandering , you must go to increase of (R24+TP3) value and increase value of source resistors to , say , 0R47
Old 18th February 2018, 11:57 AM   #375
I keep thinking that amp building would be cheaper and less troublesome than drugs, hookers and big cars? Maybe not!
Since Iím stranded on an island in the Pacific and every component change requires 4 days for new parts (without paying crazy for shipping). Can I start the first one up as is to get a feel for heat dissipation? Adjust R24+TP3 as low as possible to remain steady and monitor heat?
Does R12 need to be changed to 5K6 no matter what?
Old 18th February 2018, 12:05 PM   #376
Zen Mod's Avatar
R12 needs to be increased , to save little jfet bugger of going south
regular value is OK with regular rails , but you're in realm of Papa's ABFAB club
it stands what you intend - for R24+TP3 , monitor both heat and steadiness of Iq
Old 18th February 2018, 12:44 PM   #377
Great thanks!
These are the same heat sinks that WalterW used in his Sony VFET project. In his first post, where he tested these heat sinks, his test results were 80 watts per sink. I have 5 per amp so 400 Watts diapation?
Are you using these same sinks in your monster amp? And/or did you observe different results?
Should I start with TP3 and TP1 centered or ?
Old 18th February 2018, 12:52 PM   #378
Zen Mod's Avatar
TP3 at minimum , TP1 say centered
these big amps are having 350W of heat per case , that on 10pcs of heatsinks 250mm high
and that's 18 to 20C above ambient
go figure
Old 19th February 2018, 05:24 AM   #379
ZM, sorry to bother you some more, Iím so close and want to make sure I donít make any more mistakes. I know you have a zillion other projects going.
When I originally asked about the possibility of scaling up the Babelfish J to match my existing powers supply, you provided the schematic below in post 282. This schematic shows a 45volt supply with 0R47/3w source resistors along with some other changes. This was the schematic I bought components for originally.
Can you mark up this schematic and/or confirm what would be the best final choices? Some of the latest schematic markups of earlier versions are moving closer to the one attached below.
Thanks in advance
Old 19th February 2018, 07:35 AM   #380
Zen Mod's Avatar
aha
yup , problem often is my multitasking
in fact , I am the problem , due to multitasking
just confirm - you're having 0R47 resistor mounted now ?
About possible Babelfish J interestHide this!Advertise here!
Babelfish J2 , just one package for sale Zen Mod Swap Meet 6 22nd April 2015 02:59 PM
For interest M Gregg The Lounge 0 26th September 2014 09:50 PM
Just for interest.. M Gregg The Lounge 0 17th July 2013 08:56 PM
Babelfish J combos Zen Mod Swap Meet 0 18th June 2007 12:18 PM
Maybe of interest... Ropie Analogue Source 2 20th April 2004 07:18 PM
