Cubie2
Cubie2
Old 28th March 2015, 11:11 AM   #21
Dennis Hui is offline Dennis Hui  Canada
Hoopy Frood
Cubie2
Try here:
Tech DIY Company Store
We are fearless amplifier builders. A little heat doesn't scare us at all.
- NP 2002
Old 3rd April 2015, 04:59 AM   #22
ammel68 is offline ammel68  United States
Banned
Juma, can the gain be lowered perhaps with a higher value R16 or will that cause stability issues?
Thanks...
Old 3rd April 2015, 10:42 AM   #23
juma is offline juma  Serbia
juma's Avatar
Higher value of R16 (150R - 220R) will lower the gain without stability issues.
Old 15th April 2015, 11:41 PM   #24
marsupialx is offline marsupialx  United States
marsupialx's Avatar
Cubie 2. Getting ready to etch.
Old 16th April 2015, 01:56 PM   #25
Cambe is offline Cambe
Old 18th April 2015, 12:06 AM   #26
marsupialx's Avatar
Juma, if you could glance at this and see if I've made a stupid mistake, that would be great. I think it is ok. Thanks!
Any special resistor wattages or cap voltages? I assume 25v caps for C5 and C6. (+-15v Supply).
Old 18th April 2015, 04:07 AM   #27
Banned
10V for C3. I'm going to use 16V.
C5 and C6 25V or higher. I already have 35V lying around, so that's what I'll be using.
Old 18th April 2015, 11:58 AM   #28
juma's Avatar
I see no mistakes
You got caps all right as well as ammel68 (C3 - 10V).
All resistors are 1/4W except R20 - I used there 1/8W because of tight space but you can use 1/4W and turn it to standing position. Its value is not critical - anything from 47k to 330k will do OK.
Old 18th April 2015, 12:06 PM   #29
marsupialx's Avatar
Originally Posted by juma View Post
I see no mistakes
Thanks!!!
Old 21st April 2015, 09:39 AM   #30
acamilicko is offline acamilicko  Serbia
acamilicko's Avatar
Dear Juma,
I am now in a doubt.
http://www.diyaudio.com/forums/pass-...l-mosfets.html
I know there is topology difference between these two, but if you could let me know, which one in your opinion has slightly better sound?
To be precise, more "tube" sound?
And one more, if I go with 24V rails and 1A quiescent current on Cubie, on which power level (8 ohm load) will it leave A class?
Thanks!
Keep it simple!
Cubie2Hide this!Advertise here!
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
Copyright ©1999-2020 diyAudio
