Aelph-x separate power supply for drivers
Old 29th January 2004, 01:12 PM   #1
D3 is offline D3  England
D3's Avatar
Question Aelph-x separate power supply for drivers
Forgive me.....if I make a fool of myself......but would it be possible to install a separate psu for the driver stage of the aelph-x............or is this frought with problems......
Richard Bolton uk
Old 29th January 2004, 01:24 PM   #2
roddyama is offline roddyama  United States
diyAudio Moderator Emeritus
roddyama's Avatar
This from Nelson Pass,
Originally posted by Nelson Pass
Please note that both the Aleph and Aleph X amplifiers
require that the negative rail of the front end requires
the same voltage connection as the output stage.
The only thing you can gain with a separate + supply for the
front end is perhaps a bit less noise, but even then you can
achieve this with some decoupling to the supply rail which
powers the current source for the input diff pair.
Rodd Yamashita
Old 29th January 2004, 01:32 PM   #3
D3's Avatar
Default psu
Many thanks for the reply............
Richard Bolton UK
Aelph-x separate power supply for driversHide this!Advertise here!
Separate power supply chassis- with a difference! SHiFTY Tubes / Valves 14 21st January 2013 06:00 PM
Separate power supply - Umbilical Cord marcutan Tubes / Valves 39 27th January 2010 07:18 PM
separate chassis power supply onixuser Class D 2 4th March 2005 08:42 PM
Holton separate power supply for imp/output! B.I.G Solid State 3 15th February 2005 04:08 PM
Aleph's front end separate power supply Peter Daniel Pass Labs 24 10th April 2002 09:48 PM
Copyright ©1999-2019 diyAudio
