The BA-3 as preamp build guide
Old 14th February 2020, 04:43 AM   #1711
donhughes111 is offline donhughes111
Default Amazing...
Soundwave: First, congratulations on a successful build. But...
Holly c___. That thing is beautiful.Tell us about the case. It's off the charts cool.
Don
Old 14th February 2020, 04:53 AM   #1712
6L6 is offline 6L6  United States
6L6's Avatar
Looks like this one - Preamp Amplifier Chassis / DIY Aluminum Case DAC amp chassis /size 315*355*115MM | eBay
Old 14th February 2020, 03:13 PM   #1713
soundwavesteve is offline soundwavesteve  United States
Yup, that's the one. Machine work was very well done, everything lines up, sits level, not a scratch on it when I received it. The source selector has holes for LEDs but I have not seen anyone make this chassis and develop a way to have LEDs light up with your source position - that would be extra cool.
It looks legitimately high-end sitting on the shelf
Old 14th February 2020, 03:40 PM   #1714
It's really nice but "I" have to support the store. Diyaudio is my lifeline to learning. Couldn't do it without them.
But, Congratulations your whole build is beautiful.
Don
Old 14th February 2020, 04:30 PM   #1715
diplomata is offline diplomata  Portugal
[QUOTE=The source selector has holes for LEDs but I have not seen anyone make this chassis and develop a way to have LEDs light up with your source position - that would be extra cool.[/QUOTE]
Hello soundwavesteve
just duplicate the line selector, one half selects the input and the other selects V+ for the led you want to turn on.
Something like this:
Best regards
carlos
Old 14th February 2020, 07:29 PM   #1716
Ah, simplest solution is best! I don't know if I can do that with Glassware's Select Switch:
Stereo selector switch
If my power supply wasn't in the way I could put the GW switch as second behind another switch that was connected to the leds......
Old 14th February 2020, 07:32 PM   #1717
6L6's Avatar
You'd need a different switch, there's a drawing in this .pdf that would help explain. It's pretty easy. https://www.diyaudio.com/forums/atta...i_select-2-pdf
from here - GB For Salas I-Select Mesmerize Type input selector and volume control
Old 16th February 2020, 02:47 AM   #1718
Frogeye is offline Frogeye  United States
Question Stereo Selector Switch
Has anyone tried the Stereo Selector Switch linked in post 1716? The selector switch itself could be a rip-off of the Mesmerize, but I am primarily interested in the relay operated volume control: 128 steps! Besides the selector board board is possibly available through Tea-Bag if I can get in on a GB sometime Two of these goodies could be used to drive a BBA-3giving tracking as accurate as the builder was fastidious, as long as they were kept independent it could also allow for balance adjustment. Hmmmm, I'm interested especially because I have two BA3Gs ( only one of which is yet populated, but that could easily change,,,.
Hal
Old 16th February 2020, 03:43 PM   #1719
McQuaide is online now McQuaide  United States
I use the Glassware one from post 1716. Not sure where you are seeing 128 step volume control though.
Mark
Old 16th February 2020, 06:26 PM   #1720
eLarson is offline eLarson  United States
eLarson's Avatar
Originally Posted by soundwavesteve View Post
That is an amazing looking case. Beautiful job. 11/10.
The BA-3 as preamp build guideHide this!Advertise here!
BA-3 As Preamp vdi_nenna Pass Labs 1345 26th November 2019 05:01 AM
MyRefC build guide AndrewT Chip Amps 1119 29th July 2016 11:30 PM
Trapezoid build guide? mudchute Planet 10 hifi 22 10th November 2014 10:37 AM
MY FIRST BUILD BA-1 joesch1999 Pass Labs 15 15th May 2011 09:54 PM
FS: two burning amps (one each BA-1 and BA-2) without drivers Eric Weitzman Swap Meet 15 17th February 2010 03:35 AM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
Copyright ©1999-2020 diyAudio
