The BA-3 as preamp build guide
Old 28th May 2019, 07:10 PM   #1441
nanchangbob is offline nanchangbob  United States
nanchangbob's Avatar
I was just looking at 6L6's build and I noticed the MOSFETs are turned around, I know on some MOSFETS the drain and source can be reversed but I'm guessing it can not on these?
Does anyone have a part number for those heatsinks?
A great day to listen to music.
Old 28th May 2019, 07:20 PM   #1442
I looked at the datasheet and I see the problem
Old 28th May 2019, 08:50 PM   #1443
Zen Mod is offline Zen Mod  Serbia
Official Court Jester
Zen Mod's Avatar
good
just wanted to say that I'm better seeing details on your avatar than on pic you posted
my Papa is smarter than your Nelson !
clean thread; Cook Book;PSM LS Cook Book;Baby DiyA ;Mighty ZM's Bloggg;Papatreasure;Papa... by Mighty ZM
Old 11th June 2019, 04:31 AM   #1444
budwiser is offline budwiser  United States
Uhg, do I have a problem. Hooked up across R11, R10 and R12 as instructed. After turning pots, only R11 is showing any activity. Got to .25 volts on R11 and still no activity across R10. R12 has stayed at zero. Am I doing something wrong.. afraid to go any higher. Should R10 increase proportionately to R11 as I turn P1.
Old 11th June 2019, 05:49 AM   #1445
Hikari1 is offline Hikari1  United States
R10 and R11 is your bias.
What you are referring to as R12 is your DC offset. But you do not measure ACROSS R12. You measure after R12 and ground. Plus probe of your meter on output leg of R12 or input leg of C3 and negative meter on ground...you can use the ground pad of the PCB.
I'd start with the pots back at zero and start the biasing procedure over again. Because you are not measuring the DC offset you don't know what's going on yet.
Don't be afraid to turn the pots until you get a reading across R10/11. But try to null the dc offset as you go...it's kind of a back and forth game with the pots. The mosfets won't turn on until they reach a specific voltage so sometimes you need to turn a pot a lot until a reading shows up on R10/11.
Old 12th June 2019, 01:32 PM   #1446
Worked like a charm. Thanks
The BA-3 as preamp build guideHide this!Advertise here!
BA-3 As Preamp vdi_nenna Pass Labs 1335 22nd May 2019 11:33 PM
MyRefC build guide AndrewT Chip Amps 1119 29th July 2016 10:30 PM
Trapezoid build guide? mudchute Planet 10 hifi 22 10th November 2014 09:37 AM
MY FIRST BUILD BA-1 joesch1999 Pass Labs 15 15th May 2011 08:54 PM
FS: two burning amps (one each BA-1 and BA-2) without drivers Eric Weitzman Swap Meet 15 17th February 2010 02:35 AM
Copyright ©1999-2019 diyAudio
