The BA-3 as preamp build guide
Old 28th December 2018, 12:06 PM   #1331
McQuaide is offline McQuaide  United States
Originally Posted by Zen Mod View Post
cheer up
with mileage , I'm not smarter .... I'm just better in recognizing when short circuit between headphones is too dangerous to proceed
The problem was being off work and having too much time!
Signal chain is now all PassDIY (except when I swap the F5 with the Fisher 400). Having such simple circuits with so few caps in the chain makes for exceptional attack, dynamics, and clarity. I find I don't need as much volume to get a satisfying sound level.
Mark
Old 12th January 2019, 08:30 PM   #1332
MEPER is online now MEPER  Denmark
I have just adjusted bias on BA3-pre. Voltage is +-26.5 V. The temperature on heatsink of output transistors is 65 C. Is this considered OK or is it a bit on the high side? ….I assume that junction is well inside the limit. I could reduce voltage to 24V then I would probably get below 60 C on heatsinks.
Old 13th January 2019, 02:32 AM   #1333
nashbap is offline nashbap  United States
I think 65 is too high. Is that with lid on or off?
What is the bias you are running at?
nash
F5TV3, AVC, BA3b pre, Salas DCG3b, OBL-15
Old 13th January 2019, 09:28 AM   #1334
What is lid?
Upps…….I just se my error now looking at the schematic again. I have adjusted bias by having 2V over the 22 ohm resistors (R10, R11) so I have double bias current. Backing off to 1V will solve all problems...…...or even 1.5 V.
Are there any advantages running higher bias that specified?
Now I know where the limit is using the small heatsinks……..by accident.. :-)
Old 13th January 2019, 09:45 AM   #1335
Now I see…...lid = top cover?
No.....it was open.....so a couple of degrees more heat can be expected when lid is on. But I ordered top cover full vented so ventilation will be good.
Old 13th January 2019, 02:08 PM   #1336
6L6 is offline 6L6  United States
6L6's Avatar
Not really. Any advantage there might be in decreased distortion can be tuned much more easily and effectively with P3.
Old 17th January 2019, 10:40 PM   #1337
I noticed using these Galaxy chassis that there is no galvanic connection from the bottom to the side panels so signal and safety ground is only the bottom. Is that a problem? …..I am more concerned about noise than the safety.
The way the bottom and top is connected to the side panels via the nuts in the rails does not make a galvanic connection when the small screws are in place. At least not in my Galaxy chassis. Something more "violent" has to be done to penetrate the black layer and aluminum oxide layer.
Old 17th January 2019, 10:41 PM   #1338
6L6's Avatar
Sandpaper or a file and rough up a spot on each touching panel.
Old 18th January 2019, 07:24 AM   #1339
OK.....I "worked" the bottom and top screws a lot by loosen and fasten them a few times and it seems I succeeded in getting connection from top/bottom to side panels and also to front / back panels. Will recheck later to see if connection is persistent.
Old 2nd February 2019, 01:15 AM   #1340
lae2 is online now lae2  United States
My apologies for such a neophyte question. Is the volume control simply shunted across R1. I have not found a schematic for the build guide. If the volume control was implemented for the full blown BA3 push/pull, would the result simply be an integrated amplifier? Is there a DIY project for building BA3 push/pull as a integrated amplifier. Thank you for commenting.
The BA-3 as preamp build guideHide this!Advertise here!
BA-3 As Preamp vdi_nenna Pass Labs 1322 16th July 2018 01:23 AM
MyRefC build guide AndrewT Chip Amps 1119 29th July 2016 11:30 PM
Trapezoid build guide? mudchute Planet 10 hifi 22 10th November 2014 10:37 AM
MY FIRST BUILD BA-1 joesch1999 Pass Labs 15 15th May 2011 09:54 PM
FS: two burning amps (one each BA-1 and BA-2) without drivers Eric Weitzman Swap Meet 15 17th February 2010 03:35 AM
Copyright ©1999-2019 diyAudio
