F5Turbo Illustrated Build Guide
Joined 2002
My mistake: Apparently I couldn't divide 32 by 3. Somehow I thought it was higher. :)
There's arguably a bit more linearity with the jfets at a higher voltage. (Obviously
not too high since that's the whole point of the cascode). With 32V rails,
your original 10k should be fine even as long as you're not using V-grade jfets.
There's no change in gain.
So I've done all of these interconnects in 20ga Dueland wire. Should some of these be a larger gauge? Like the Output and Ground?
to jamesvhf #1271
Hello jamesvhf,
I have built F5T -V3-Monoblocks. They run on +-42.8V. Each Monoblock has a 1000 W toroid and some caps....
Excellent poweramps with my electrostatic Loudspeakers (Audiostatic ES300R)!
I use an active crossover for the sub at 80Hz. BA-3 poweramp is driving the subwoofer (JBL 15 inch).
Cheers
Dirk
to jamesvhf #1275
Good morning jamesvhf,
a Plitron with 625 W and sec. AC output of 2x 30V AC will be absolutely enough. (My transformers are also 2 x 30 V AC out)
Rule-of-thumb: multiply your sec. AC V of the toroid with 1.3 to 1.4.
So you will 'land' anywhere between +-39V and +-43V DC after the cap bank.
I have a CRC- filter. It also depends on the values of your resistors between the caps.
Greets
Dirk :D
Very impressive system Dirk. I don't normally associate a Class A with electrostatics due to the power requirements. Or with a sub amp for that matter for the same reason. I'm sure it sounds great. I'm now thinking Honey Badger to power a pair of OB subs to compliment my F5 and F5T that will power my LX-Mini system. This DIY thing never stops, does it? Or I hope it doesn't.
in my humble opinion, the honey badger for a sub is just waist of a fantastic amp. Also, a 5 pair slewmaster would do the job better. For sub use you don't need anything more fancy then class D. I use hypex amps for sub use, and 5ch of honey badger for front, center and back (soon to be 7ch of honey badger).
