Aleph J illustrated build guide
Old 7th November 2019, 05:29 PM   #4121
Zen Mod is offline Zen Mod  Serbia
Official Court Jester
Zen Mod's Avatar
@Eric
exact schm and pics
my Papa is smarter than your Nelson !
clean thread; Cook Book;PSM LS Cook Book;Baby DiyA ;Mighty ZM's Bloggg;Papatreasure;Papa... by Mighty ZM
Old 8th November 2019, 12:18 AM   #4122
Eric is online now Eric  United States
Eric's Avatar
Here are the images, Zen. They aren't the greatest images, but they are what I have right now. The boards are populated as per the BOM from the DIYA store page. I cut the ground trace to separate the speaker ground from PSU ground and replaced it with either a 10R or 20R (I don't remember which) in order to tame a little bit of hum that I get when both inputs are connected. The big PIO cap has since been replaced with yellow MKC cap.
The PSU is an outboard configuration that I also used with my F4 and M2 amps without any problem. It uses a single Teabag PSU board which features a CRC configuration. It uses a 3-wire umbilical cord with Neutrik termination. Inside the amp, each channel gets its own pos and neg PSU cap.
DIY Theater, Aleph-X Amps, LDR based BA-3 pre, B1 Korg, Pearl II, modified SL-1200 TT, F4, M2, Aleph-J, MoFo, a40, ACAs, FHXL & TB 1772 speakers
Old 8th November 2019, 05:44 AM   #4123
codyt is offline codyt  United States
codyt's Avatar
Anyone recommend a capacitor for 3300pf cap in the ac supply line? I’ve not messed with line capacitors before, and unsure what kind of specs (aside from capacitance) I need to shot for.
Old 8th November 2019, 05:53 AM   #4124
6L6 is offline 6L6  United States
6L6's Avatar
This is nice-
C921U332MZVDBA7317 KEMET | Mouser
Old 8th November 2019, 06:26 AM   #4125
Ben Mah is offline Ben Mah  Canada
The capacitor that is second from the top is not wired to the same terminals as the other three.
Old 8th November 2019, 08:09 AM   #4126
codyt's Avatar
Originally Posted by 6L6 View Post
Thanks!
Old 8th November 2019, 12:39 PM   #4127
Eric's Avatar
The top two caps feed the channel in the left side of the image. The two bottom caps feed the channel in the right side of the image.
Old 8th November 2019, 02:40 PM   #4128
I understand that. However, the red wires to the second cap (positive pin) is to a different pin than at the other three caps.
Old 8th November 2019, 07:19 PM   #4129
Eric's Avatar
OMG I've been looking at this for a long time and just didn't see that..
Given the current that circulates through here, I'm lucky this didn't cause a real problem for me. I bet this is the cause for both of my problems: hum and the turn-off chirp.
This is easy enough to explore tonight! Thank you!
Old 8th November 2019, 08:05 PM   #4130
You're welcome. I hope it works out.
Aleph J illustrated build guideHide this!Advertise here!
An illustrated guide to building an F5 6L6 Pass Labs 1214 12th September 2019 09:23 PM
MyRefC build guide AndrewT Chip Amps 1119 29th July 2016 11:30 PM
An illustrated guide for Aleph 60 builders PKI Pass Labs 58 12th October 2013 08:13 PM
Aleph J Stuffing guide ? thor61 Pass Labs 2 4th September 2011 09:02 PM
My first step by step LM3886 illustrated build kgb_m3 Chip Amps 19 17th February 2010 05:46 PM
Copyright ©1999-2019 diyAudio
