Aleph J illustrated build guide
Old 13th October 2019, 10:00 PM   #4051
Russellc is online now Russellc  United States
Originally Posted by WKCox View Post
Just measured my Aleph J boards recently purchased from the diyAudio store and none of the mounting eyelets are at ground potential. One looks like it could be, but looking closely, it has been isolated from the ground plane. Just FYI before you cut.
I doubt, short of some reason I dont see, (and there could be many!) that I will bother. My boards are from a while back when 6L6 had a parts group buy for the Aleph J.
Unless a compelling reason, safety or sound improvement I am not going to mess with it whether the brass standoff goes to ground or not.....
Russellc
Pass B-1 preamp, Pass BA3 preamp, Wayne's 2018 LS, Pass F-5 Amp, Pass F-6 Amp, Pass BA-3 Amp, Pass M-2 amp, Pass Aleph J amp, Pass Pearl 2 Phono pre Tekton Enzo, Altec A7, Econowave JBL 2235H & B&C CD
Old 14th October 2019, 05:33 PM   #4052
astromo is offline astromo  Australia
astromo's Avatar
Thanks for that intel.
I've got a couple of tweaks in the pipeline, so I'll see what my DMM has to say when I get the chance.
As with others commenting similar thoughts, my Aleph J doesn't sound broke - so there's no immediate fix needed.
Old 15th October 2019, 06:30 AM   #4053
astromo's Avatar
Originally Posted by Extreme_Boky View Post
Why use TH1 thermistor when Aleph J PCB has one of its mounting eyelets sitting at chassis potential if brass standoffs are used?
TH1 only makes sense if that eyelet is isolated from the heatsink (chassis).
Based on the board layout from the design thread at Post #48, the trace that appears to come closest to an eyelet is V+ at the bottom left corner:
Is this the eyelet you're concerned about? If not, then which one?
Feel free for anyone to correct me if I've picked out the wrong board layout pic.
Old 15th October 2019, 08:26 AM   #4054
Extreme_Boky is offline Extreme_Boky
I have checked the PCB again, only this time with an extra pair of glasses so that I can see little things properly. Well, I owe an apology to everyone for a false alarm. I am getting too fricken old... sorry guys!
The area with ground fill is very small, resembling T ground topology, and is done properly. All good.
I had an ACA PCB on my mind when I looked at the AlephJ PCB; ACA PCB does have an eyelet that is a part of the ground track and this is correct for the ACA amp because there are no thermistors / any other ground connections.
Old 22nd October 2019, 10:36 AM   #4055
xbitwise is offline xbitwise  Europe
Dear Aleph J builders,
I just finished my Aleph J build - first real electronics project since 25 years.
I have chosen Aleph J as it has an opinion of mellow, gentle amp - exactly what I was looking for. Unfortunately I am quite unhappy with the sound. I do not speak audiophile lingua but will do my best to describe my problem:
The sound seems to be congested - all instruments together - no separation. A lot of details but no soundstage - everything is garbled together. Also fatigue comes after just couple minutes of listening - seems to be related to high frequencies which are quite tiring. No hum, no noise abut definitely not mellow. My (very) old HK 630 delivers a great soundstage and instruments isolation - I can listening it for hours - not so with Aleph J, unfortunately...
Well, as so many happy builders cannot be all wrong - I assume a problem must be with my build. I would appreciate any suggestion about how I could improve a sound quality of my Aleph J.
Thanks in advance!
Old 22nd October 2019, 10:53 AM   #4056
Steve Duffy is offline Steve Duffy  New Zealand
Steve Duffy's Avatar
Pre amp? Speakers?
Our hobby, consists of nothing more, than doing the job of poor paid laborers in our own time and at our own cost.
Old 22nd October 2019, 11:02 AM   #4057
Originally Posted by Steve Duffy View Post
Pre amp? Speakers?
Ah, right.
- DAC/preamp: RME ADI-2 DAC
- Speakers: vintage Canton Quinto 520
PCBs are all from diyaudio shop, matched Mosfets from reputable German seller, matched Jfets from eBuy seller recommended on on one for the forums here. Transformer from Toroidy. The rest of the parts is from Mouser.
Bias, DC measurements are correct.
Last edited by xbitwise; 22nd October 2019 at 11:09 AM. Reason: added measures info
Old 22nd October 2019, 11:54 AM   #4058
Can you post the photos? Input wiring, RCA's, PCB wiring.
How did you ground the PCB's? Show us the PCB grounding arrangement - power supply negative, speaker negative, XLR shield.
Are you using Aleph J in balanced input mode (your DAC has balanced out XLR's...)
Did you try swapping the hot and cold on XLR's?
Toroidy has a large number of static shielding wires... how did you connect those?
Are you sure the JFET's are of a correct grade? Measure the voltage drop across R8 and then calculate the current, I think it should be around 8mA. Then, measure the Vgs at each JFET - i think it should be 0.2V.
I think the voltage drop across R7 should be close to 4V to open the MOSFETs.
Check the components in the output CCS, especially the AC gain components and confirm they are correct. Vce on Q4 should also be close to 4V
Make sure that you did not swap the resistors R1 (R3) and R2 (R4)
If you have an oscilloscope, load the Aleph J channels with something like 10ohm / 50W resistors and check the symmetry and clipping at 20Hz, 10Khz, 20kHz
Also, make sure the MOSFETS are not oscillating !!!! Use 1:10 on probes
Old 22nd October 2019, 12:35 PM   #4059
astromo's Avatar
Thanks in advance!
Doing a voltage survey such as this example, Post #3783 could / might help.
Old 22nd October 2019, 02:07 PM   #4060
aljordan is online now aljordan  United States
Just a note on the fatigue. Mine was measuring perfectly but the highs were extremely fatiguing for the first month compared to my other amps. It eventually settled in nicely and now sounds very smooth. I never had the soundstage issue you describe. Maybe the speaker impedance is not ideally suited to the Aleph J.
Aleph J illustrated build guideHide this!Advertise here!
An illustrated guide to building an F5 6L6 Pass Labs 1214 12th September 2019 09:23 PM
MyRefC build guide AndrewT Chip Amps 1119 29th July 2016 11:30 PM
An illustrated guide for Aleph 60 builders PKI Pass Labs 58 12th October 2013 08:13 PM
Aleph J Stuffing guide ? thor61 Pass Labs 2 4th September 2011 09:02 PM
My first step by step LM3886 illustrated build kgb_m3 Chip Amps 19 17th February 2010 05:46 PM
Copyright ©1999-2019 diyAudio
