Aleph J illustrated build guide
Old 10th September 2019, 07:32 PM   #3871
Zen Mod is offline Zen Mod  Serbia
Official Court Jester
Zen Mod's Avatar
everything OK
dc offset?
my Papa is smarter than your Nelson !
clean thread; Cook Book;PSM LS Cook Book;Baby DiyA ;Mighty ZM's Bloggg;Papatreasure;Papa... by Mighty ZM
Old 10th September 2019, 08:38 PM   #3872
ontool is offline ontool
Originally Posted by Zen Mod View Post
dc offset?
Yes, on the resistors, the 0.47th output transistor at a temperature of ~ 70 * C, a voltage of 0.4 volts. That sounds very good.
Thanks to Mr. Pass , simplicity is the key to reliability and quality
Old 13th September 2019, 09:09 AM   #3873
everything OK
The bias voltage and the quiescent current on both channels are the same, but the gain on one channel is slightly less, the question is how to combine them to get the same signal level?
Old 13th September 2019, 09:41 AM   #3874
mbrennwa is offline mbrennwa  Switzerland
mbrennwa's Avatar
As far as I can tell from your video, the DVM was set to read DC voltage across the speaker terminals. How is this going to tell you anything about the gain (AC!) of your amp?
You'd need to hook up your amp such that both channels get the same input (I'd suggest a 100 mV sine at 100 Hz or so) and then read the AC voltages across the speaker terminals of both channels in order to learn something about the gain balance of the two channels.
Group buy for augerpro waveguides for Scan Speak tweeters -- elliptical version -- circular version
Old 13th September 2019, 09:53 AM   #3875
The video shows the voltage offset at the output of the amplifier.
The difference in gain on each channel is audible even without measurements. The question was what is regulated, how can I level both channels, ok?
Old 13th September 2019, 03:51 PM   #3876
Dennis Hui is offline Dennis Hui  Canada
Hoopy Frood
Hi Roo2,
Any news on your AJ build?
Dennis
We are fearless amplifier builders. A little heat doesn't scare us at all.
- NP 2002
Old 18th September 2019, 03:12 PM   #3877
Myint67 is offline Myint67  Singapore
Default One Chanel no sound
Hello my aleph J one Chanel is no sound .
Basic is .47 MV and DC cannot set (-0000.00)
Pls tell me what can I do now ?
Best regards
Myint
Old 18th September 2019, 03:26 PM   #3878
Zen Mod's Avatar
if you have genuine JFets in input ( BL range) , if all resistors are the same ,there is no reason that channels are having different gain
check all resistors , if there is no doubt in JFets
Best regards
Myint
pics
Old 18th September 2019, 04:17 PM   #3879
ItsAllInMyHead is online now ItsAllInMyHead  United States
I got the Aleph J updated to dual-mono. Thanks to everyone for the advice, particularly ZM and @TungstenAudio. ZM, I'll get the fuses put into the SissySIT next.
It's getting back up to operating temp in the main system, but everything checked out wonderfully with the test rig.
Before and After...
Old 18th September 2019, 04:35 PM   #3880
TungstenAudio is offline TungstenAudio  United States
Nicely done! Very tidy
Aleph J illustrated build guideHide this!Advertise here!
An illustrated guide to building an F5 6L6 Pass Labs 1214 12th September 2019 08:23 PM
MyRefC build guide AndrewT Chip Amps 1119 29th July 2016 10:30 PM
An illustrated guide for Aleph 60 builders PKI Pass Labs 58 12th October 2013 07:13 PM
Aleph J Stuffing guide ? thor61 Pass Labs 2 4th September 2011 08:02 PM
My first step by step LM3886 illustrated build kgb_m3 Chip Amps 19 17th February 2010 04:46 PM
Copyright ©1999-2019 diyAudio
