Aleph J illustrated build guide
Old 20th May 2019, 03:30 AM   #3641
6L6 is offline 6L6  United States
6L6's Avatar
Don't need anything extra but the switch.
Hmmm... It's actually a very interesting idea. The biggest thing that immediately comes to mind is make sure it's powered off when you throw that switch, but aside that, It's not ringing any alarm bells in my head.
Start a thread, take a bunch of photos and go for it.
Old 20th May 2019, 06:00 AM   #3642
Zen Mod is offline Zen Mod  Serbia
Official Court Jester
Zen Mod's Avatar
I don't like idea of switching high DC inrush currents
maybe using solid state relays, so small 3PDT toggle switch operating them
besides that , it comes to my mind - each channel (of 2+2) having own dedicated speaker , or you intend to drive just one pair , using different amp for different mood ?
my Papa is smarter than your Nelson !
clean thread; Cook Book;PSM LS Cook Book;Baby DiyA ;Mighty ZM's Bloggg;Papatreasure;Papa... by Mighty ZM
Old 20th May 2019, 07:44 AM   #3643
Extreme_Boky is offline Extreme_Boky
Modify the biasing circuit to cut-out an undesired module class A bias.
Old 20th May 2019, 08:12 AM   #3644
Itsmee is offline Itsmee  England
Itsmee's Avatar
Originally Posted by aljordan View Post
...set up the two chassis so that each has an M2 board and an Aleph J board...
Forget the switch, biamp.
Old 21st May 2019, 06:17 PM   #3645
Mazeppa is offline Mazeppa  United States
Mazeppa's Avatar
Yes indeed, DC is difficult to switch safely.
6L6 addressed that adequately.
besides that , it comes to my mind - each channel (of 2+2) having own dedicated speaker , or you intend to drive just one pair , using different amp for different mood?
Good question. I've pondered having a system that could be readily switched from rock and roll amp/speakers to singer and guitar amp/speakers.
Bit of a stretch highly contingent on whether 2 pair speakers could be properly placed in the same listening area. At any rate, I'll have to wait until I retire to pursue the notion. Probably best to keep working toward a system that does everything well.
CD transport<Schiit Gungnir Multibit DAC<Schiit Saga Pre<ACA's in mono parallel<Tekton Lore Reference or Omega Super 3XRS
Old 21st May 2019, 06:18 PM   #3646
Mazeppa's Avatar
+1
Old Today, 01:13 AM   #3647
Mazeppa's Avatar
Default Success!
Originally Posted by KevinHeem View Post
I know on Pearl II projects people have had problems in the past with the ZTX450 going bad due static electricity before/during installation. Maybe you should try replacing all three ZTX components.
Replaced Q2,3,4 in board #1.
Fired it up, and whaddaya know, readings across source resistor and DC offset were in the ballpark.
Did anybody hear my whoop and holler?
Adjusted R27 to .350v across source resistor, DC offset is .035v.
1/2 hr warmup, adjusted to .400v and .000v.
Lid on for another 1/2 hr; adjusted bias from.384 to .400, offset from.005 to .000.
Checked board #2 bias .378, adjusted to .400, offset from .005 to .000.
Power down, take the wife out to supper.
Power up, bias on both sides .430-ish, did not adjust, offsets .003-ish, did not adjust. Power down.
Connect test speakers and Spotify, power up and we have clean music from not one, but TWO channels.
Zero turn on thump, or noise of any kind. 1rst song through a new amp is a big deal, Jimi Hendrix got the job with "All Along the Watchtower".
Oooh-la-la, can't stop grinning.
Many thanks to the group for the help and encouragement.
Old Today, 01:22 AM   #3648
Dennis Hui is offline Dennis Hui  Canada
Hoopy Frood
Congratulations!
We are fearless amplifier builders. A little heat doesn't scare us at all.
- NP 2002
Old Today, 01:56 AM   #3649
WKCox is offline WKCox  United States
WKCox's Avatar
Great to hear you solved the problem! Now relax with more Hendrix and a bit of Cream.
Pass F5, M2x, ACA, B1, B1 Korg; Audio Research ST-70-C3; Dynaco ST-35; Audio Electronic Supply SE-1; Elekit TU-8500; Hagerman Bugle; Scan-Speak Solist MTM; Selah SA-1; Seas Loki; Cavalli eXStatA; Millett Hybrid MAX, Hybrid MiniMAX
Old Today, 02:17 AM   #3650
Russellc is offline Russellc  United States
There you go. This is a great amp, one of the best. Congrats.
Russellc
Pass B-1 preamp, Pass BA3 preamp, Wayne's 2018 LS, Pass F-5 Amp, Pass F-6 Amp, Pass BA-3 Amp, Pass M-2 amp, Pass Aleph J amp, Pass Pearl 2 Phono pre Tekton Enzo, Altec A7, Econowave JBL 2235H & B&C CD
Aleph J illustrated build guideHide this!Advertise here!
An illustrated guide to building an F5 6L6 Pass Labs 1185 4th April 2019 03:42 AM
MyRefC build guide AndrewT Chip Amps 1119 29th July 2016 10:30 PM
An illustrated guide for Aleph 60 builders PKI Pass Labs 58 12th October 2013 07:13 PM
Aleph J Stuffing guide ? thor61 Pass Labs 2 4th September 2011 08:02 PM
My first step by step LM3886 illustrated build kgb_m3 Chip Amps 19 17th February 2010 04:46 PM
Copyright ©1999-2019 diyAudio
