Aleph J illustrated build guide
Old 15th May 2019, 01:04 PM   #3631
stefanoallavoro is offline stefanoallavoro
Nice answer...but seriously? Where? after the first resistors r1, r3 with a T circuit?
Old 15th May 2019, 02:45 PM   #3632
Mazeppa is offline Mazeppa  United States
Mazeppa's Avatar
Originally Posted by Mazeppa View Post
Goofball audio electronics wizard with a heart of gold, you are.
So long as I'm at it; 6L6 and MJ to name 2 of a few should be recognized (maybe sans the goofball appellation, though they both have their moments)
as well.
This community in general has really good folks in it.
As has been said in Arkansas at such times; "Y'all are awright by me."
CD transport<Schiit Gungnir Multibit DAC<Schiit Saga Pre<ACA's in mono parallel<Tekton Lore Reference or Omega Super 3XRS
Old 15th May 2019, 04:12 PM   #3633
RafaPolit is offline RafaPolit  Ecuador
RafaPolit's Avatar
I don't think its that easy, is it? That's why there are Buffers and Preamps that do this but keeping impedances in the 'correct' realm.
A power amp just does it's thing, no volume control. Perhaps for testing purposes, but not for a final solution.
I know nothing about this though. Maybe it is as easy.
Old 15th May 2019, 04:52 PM   #3634
6L6 is offline 6L6  United States
6L6's Avatar
Yes, it is that easy.
Potentiometer is placed in front of amplifier input, amplifier input now takes signal from potentiometer wiper.
Potentiometer is nothing more than a voltage divider.
Old 15th May 2019, 05:19 PM   #3635
Itsmee is offline Itsmee  England
Itsmee's Avatar
Originally Posted by 6L6 View Post
Yes, it is that easy. ...
Old 15th May 2019, 06:22 PM   #3636
Thanks Itsmee for the answer..but the problem is that the amplifier has an balanced input...so I suppose I cannot reduce the voltage of the + line only...
Old 15th May 2019, 07:04 PM   #3637
Mark Johnson is offline Mark Johnson  United States
Mark Johnson's Avatar
Same answer still applies.
Big question...how and where insert a potentiometer for volume control. Thanks for the answers
In front. After dealing with the surprise unstated detail that the amp has balanced inputs, you can deal with the surprise unstated detail that the potentiometer has 4 gangs. Two for the left channel (+ side and - side), two more for the right channel (+ side and - side).
Here is one example
9mm ALPS A50K 50K Audio Taper Potentiometer 15mm Knurled Shaft 4 Gang-in Potentiometers from Electronic Components & Supplies on Aliexpress.com | Alibaba Group
Old 15th May 2019, 10:43 PM   #3638
thanks Mark..I'll try and refer my trial on the chat
Old 20th May 2019, 03:01 AM   #3639
aljordan is offline aljordan  United States
I am thinking about monoblocks and saving money on chassis and power supplies. Would someone tell me if the following would not work, or otherwise be a bad idea? I am a liberal arts guy, not an engineer, so please be gentle.
I have an Aleph J and an M2, each in a Deluxe 4U DIY Audio Store chassis, and both with very similar power supplies (maybe the brand of capacitors are different). If I wanted to convert them to monoblocks without buying extra chassis and power supplies, could I set up the two chassis so that each has an M2 board and an Aleph J board, then install a heavy duty 3PDT toggle switch so that the power supply would only power one board at any given time?
Old 20th May 2019, 03:27 AM   #3640
Mazeppa's Avatar
Long ways from an audio electronics guru myself, but that sounds like a capital idea to me.
Have you got room on the back panel for the additional input and output connectors?
Aleph J illustrated build guideHide this!Advertise here!
An illustrated guide to building an F5 6L6 Pass Labs 1185 4th April 2019 03:42 AM
MyRefC build guide AndrewT Chip Amps 1119 29th July 2016 10:30 PM
An illustrated guide for Aleph 60 builders PKI Pass Labs 58 12th October 2013 07:13 PM
Aleph J Stuffing guide ? thor61 Pass Labs 2 4th September 2011 08:02 PM
My first step by step LM3886 illustrated build kgb_m3 Chip Amps 19 17th February 2010 04:46 PM
Copyright ©1999-2019 diyAudio
