Home | Forums | Rules | Articles | diyAudio Store | Blogs | Gallery | Wiki | Register | Donations | FAQ | Calendar | Search | Today's Posts | Mark Forums Read | Search |
Pass Labs This forum is dedicated to Pass Labs discussion. |
#3401 | |
Everyone knows that it is difficult to explain the circuit of the Nielsen Pass with textbooks. Can you explain? ? I also have the basics of these textbooks. If you can't explain it, don't talk about it. . . . . . |
#3402 |
The input stage is a classic differential amplifier with a CCS (constant current source) on the positive rail.
R8 controls current through the pair. R7 controls the DC operating point of the positive output node, and hence the DC offset further down the circuit, as this amplifier is DC coupled.
Illustrated Build Guides - Pass F4 - Pass B1 - Pass F5 - Pearl 2 - O2 HPA - Hagerman Bugle 2 - Pass Aleph J - Me at BA '13 -Pass F5Turbo - BA-3 Amp - BA-3 Preamp - F6 AmpCampAmp Me at BAF '18https://www.youtube.com/watch?v=pl0GniCEoVk |
#3403 |
dc coupled = no coupling caps between stages...
and when you do that, dc levels from the stage is looking at the base or gate of the next device....and you will have to do something about it..
planet10 needs your help: Let's help Ruth and Dave...http://www.diyaudio.com/forums/plane...ml#post5010547[B |
#3404 | |
edit: we are all here to help, but you should help yourself too...
#3405 | |
#3406 | |
#3407 |
Had nothing to to with newbie or not.
I thought about to explain it. (at least as far as I understood it) Maybe its my bad english. But the way the question was asked... ...in germany no one will get a answer this way. Sounds like... Here i am, i want an answer... ...then i think -> go and look for yourself. A question like: I`ve no idea how this or that works. I`ve looked in the www. found something but i do get it. can some help or explain? Will get another response from me. |
#3408 | |
I work in a similar way. Some explanation of the journey that includes giving those with the knowledge an understanding of what the query holder understands helps a lot. It means that redundant advice is not offered and the query holder is likely to get a useful answer with less fuss. |
#3409 |
Hello all,
The Aleph J that I built gives a bit too much presence and zing in the upper mids / lower treble with my speakers (Klipsch Forte II). I've built a pair of ACAs and and an M2, which both work very well with the speakers. Maybe it is just how the Aleph J sound with the Forte II, but I am wondering if swapping some caps or other part might mellow the amp a bit. I built the amp pretty much according to the BOM linked in the beginning of the thread. For the power supply, I used a 300 VA 18 volt Antec transformer, and eight 22,000 uf 35 volt Cornell Dubilier caps on the store's board, using packaged bridge rectifiers recommended elsewhere on the Pass threads. It is very similar to the power supply I used on the M2. Maybe the amp is supposed to have this quality to the highs, but if anyone has any ideas, I'd enjoy trying some suggestions. Thanks, Alan |
#3410 |
Honestly have never heard of somebody wanting to mellow out an Aleph...
Try with some different speakers to determine if it’s the amp or the interaction of the amp and those particular speakers, as you might suspect.
Thread | Thread Starter | Forum | Replies | Last Post |
An illustrated guide to building an F5 | 6L6 | Pass Labs | 1160 | 14th February 2019 04:14 PM |
MyRefC build guide | AndrewT | Chip Amps | 1119 | 29th July 2016 11:30 PM |
An illustrated guide for Aleph 60 builders | PKI | Pass Labs | 58 | 12th October 2013 08:13 PM |
Aleph J Stuffing guide ? | thor61 | Pass Labs | 2 | 4th September 2011 09:02 PM |
My first step by step LM3886 illustrated build | kgb_m3 | Chip Amps | 19 | 17th February 2010 05:46 PM |
New To Site? | Need Help? |
