Aleph J illustrated build guide
6L6's recommendation for the AJ to follow up my ACA project worked out so well, now he's on my shoulder whispering "M2X, M2X......".
So, does anybody have a line on mono block chassis with adequate heat sinks?
Maybe I'll go with 2 diyAudio store 4U's, each containing an M2X and SissySIT board. Have to do some measuring and see if they would fit into my IKEA towel shelves/stereo rack.
2515 Aluminum Single radiator Enclosure Amplifier Chassis/ Preamp Case/ PSU Box | eBay ?
I did what you are thinking about a while back but with an Aleph J and an M2. See this thread for details.
If I build monoblocks with two 200VA transformers, is it a possible (and good) solution to build a PSU like that for each channel?
With those resistors (or smaller R value):
And those caps:
Thanks for help :cheers:
I have a modular external power supply I use with my Aleph-J, M2, and M4 amps. The power supply is arranged in CRC fashion, using 3 x 0R22 3w mills wire wound resistors on each rail. This works fine and they only get mildly warm. Just mount them in free air so they can cool a little. I would aim for no more than 0R1 total resistance between caps and go for about 10w total power rating - mine are 9w.
Many thanks, Eric :cheers:
An excellent approach, and in hindsight I wish I'd have gone that way.
B-u-u-t, I went with a 5U chassis intending to swap amp boards as time went on. Also seemed like a good idea, but now I don't want to muck with the AJ, lest I mess up its mojo with my sometimes clumsy electronics work.
Remember, I'm an electrician that can solder and if I run into trouble that requires an electronics man, I've put myself in deep merde.
Yes, I did have a spot of trouble getting the AJ going, and yes, the forum brothers got me through it.
However, that was dicey enough that I'm wanting to get a back up amp going before I go messing about in the 5U/AJ with anything like a 2nd set of boards, or raising the bias a tad, or bypassing C1, etc.
Nothing to it, but to do it.
I just need to get some chassis and PS components ordered and go to work instead of talking about it.
Then I fire up my system, get lost in well reproduced music and wonder why I want to change anything.
Great problem to have.
I calculated around 23Vdc on rails. Am I wrong?
What is the problem with wirewound resistors?
The alternative is thick film with heatsink...
25V caps should be Ok, but still I would use 35V caps to be on the safe side :)
Not sure if it matters here, but most wirewound resistors are inductive.
I see that Panasonic 3W resistors are NRND. What about Vishay/Dale 3W CPF resistors?
