Aleph J illustrated build guide
Dear team,
I'm building up a Aleph J from the DIYStore and so far it's very clear with all the posts here and easy. I've built (10y ago) a KT88 Class A valve amp as well as Zen Headphone which I still love as well as an Aleph 3 (Aleph J and 3 will share the case and PSU with a switch to allow to choose which amp. I still love my A-3!). I just bought 2x B1 Korg + 1 "Noir" headphones kit I'll need to work after the Aleph J is done... As you can see a lot of good projects in the making! Plus I just found 2 fostex FW305 for a good price so I bought them too (to complement a Backloadedhorn FE206) that I built too. Anyway my skills are good in soldering and pretty ok to understand but sometime I've dumb questions :)
Anyway my question is something that has been asked and I didn't find a clear answer. I've bought 25 IRF240 and I'm planning to match them. I've an adjustable PSU (0-30V and 0-10A) and before I start measuring the Vgs I wanted to check if I can use it to match them and what should be the Volts/Amps to test them.
Thanks in advance!
Fred
Dear team,
Thanks in advance!
Fred
I copied the current source from the amplifier and mad a test jig that actually tests at the operating condition of the fet. Worked well fo me.
Aleph J is alive! Below are a few pictures of J up and running in my system.
I read through this entire thread three times between when I decided to take on this project and when I completed it yesterday. I had relatively few questions, but that is only because of the effort and contributions from everyone on the thread previously, so thank you.
I did have an issue setting the offset on the left channel on my initial startup and test. The pot I had used was bad, I could hear the pot click as I turned it, despite the fact I tested the pot and set the pot during assembly. Luckily I had a couple extras and was able to pull the board off and replace that pot.
I had a minor issue with hum when I first connected the amplifier to my system running to my Klipsch RP-600Ms. Standing the Antek on end, rearranging the mains/secondary wiring, and making sure to push the input runs up against the sides of the chassis made all the difference and I now how a completely black background thru the RP-600Ms.
This was my first DIY audio project, and the first time I have soldered anything since I was a kid helping my dad. It seems daunting at the start, but a methodical approach of testing, building, testing and testing some more along the course of the entire build I certainly think made things much easier.
Couldnt be happier!
