Pass Aleph P 1.7 preamp builders thread
Old 31st January 2019, 09:12 AM   #591
Zen Mod is offline Zen Mod  Serbia
Official Court Jester
Zen Mod's Avatar
nulling of 2nd is normal thing with balanced stages
you need to deliberately spoil symmetry , to invoke 2nd
my Papa is smarter than your Nelson !
clean thread; Cook Book;PSM LS Cook Book;Baby DiyA ;Mighty ZM's Bloggg;Papatreasure;Papa...© by Mighty ZM
Old 31st January 2019, 09:42 AM   #592
generg is offline generg  Germany
generg's Avatar
My experience is that the Aleph P 1.7 sounds despite its k3 dominance with a good body.
Hearing it you could suppose that it is k2 dominant.
and the First Wtt is......a really First Class PSS Idea
Old 2nd February 2019, 08:30 AM   #593
albertNL is offline albertNL  Australia
It looks like the distortion/oscillation issue is finally fixed. Just to reiterate, I run the amp with the 10k input resistors bypassed and made 3 modifications:
  • gate stopper resistors (gain irf610's only; 4x) changed from 221R to 620R. Did not fix the problem but I left them in as I could not be bothered to remove the board from the case again. I may suffer some high frequency roll off as a result, but at my age I will probably not hear it.
  • added 221R in series with the input (IN+ and IN-, L + R; 4x). Fixed the problem.
  • 10uF film cap across psu zener stack (dual mono; 2x).
If anyone runs into oscillation problems, try the following:
If you have the input protection zeners installed, try switching the 10k input resistors in series with the input. If this cures the oscillation try 221R input resistors like I did. If it does not help or you did not have input protection zeners, you have a completely different problem than I had.
My amp is playing beautiful music in my workshop where it will stay for a while to make sure it keeps working normally before it moves to my study.
I have added 2 ARTA screenshots. They show some mains noise but with unpotted transformers in the amp case that is to be expected.
Overall, I am happy with my new AP1.7!
Thanks to everyone for your help!
Albert
PS If you are doing precision measurements, switch off your power wheelchair. I was surprised how much noise my wheelchair electronics generate until I realised that it is unshielded, close to the bench (duh!) and the motors require huge amperage to move from standstill (the controller outputs 120A per motor!).
Old 2nd February 2019, 08:57 AM   #594
generg's Avatar
Congratulations Albert!
Bah, a wheel chair is really a powerful device!
Maybe you find some XA25 pucks in it!
Old 2nd February 2019, 12:35 PM   #595
Bfpca is offline Bfpca  Canada
Albert
Thank You Albert for doing such a great job of documenting and explaining this problem. You have shown great patience and determination throughout the process. I wish you happy listening with your 1.7. I may have to revisit my Aleph J now, as I desperately need a balanced preamp.
P.S.- Power transformer potting will likely reduce mechanical noise from the transformer but I don’t believe it will reduce electrical noise being transformed from the primary to the secondary side. A good line filter is something I like to include in my preamp designs.
Brian
Old 4th February 2019, 07:40 AM   #596
Originally Posted by Bfpca View Post
P.S.- Power transformer potting will likely reduce mechanical noise from the transformer but I donít believe it will reduce electrical noise being transformed from the primary to the secondary side. A good line filter is something I like to include in my preamp designs.
Thanks Brian. With regard to the transformers I think I did not explain myself correctly. I meant to say that I have 2 "naked" 30VA R-Cores plus a 30VA toroid in the same case as the amp board. The transformers could be the reason I am picking up mains noise. The transformers have no shielding, so not the fancy ones like Toroidal transformers SUPREME AUDIO GRADE V2 - Shop Toroidy.pl
Old 4th February 2019, 11:55 AM   #597
Mark Allen is offline Mark Allen  United States
My transformer is unshielded yet I have no noise. I believe the original Pass transformers were also unshielded. My SN measured out at over 90 db.
Mark
Old 4th February 2019, 12:12 PM   #598
Hi Mark,
I don't hear any noise but the Arta FFT graphs above show there is some measurable mains noise. About 110dB below the primary signal, so it is fine. :-)
I assume it can be lowered by moving the transformers and rectifier diodes to a separate box, but at this level I will not bother.
Pass Aleph P 1.7 preamp builders threadHide this!Advertise here!
F3 Builders Thread Melon Head Pass Labs 650 11th January 2019 01:31 PM
B1 builders thread Bas Horneman Pass Labs 728 12th March 2018 07:45 PM
ezDAC v.1.5 Builders Thread ezkcdude Digital Line Level 366 14th March 2013 04:31 PM
Preamp for Pass Aleph 0s? Vermeer Pass Labs 5 21st October 2004 12:46 AM
pass aleph L preamp service manual SDF Pass Labs 1 14th June 2002 06:19 PM
Copyright ©1999-2019 diyAudio
