A guide to building the Pass F4 amplifier.
Thread Tools
Old 22nd July 2021, 09:10 PM   #2781
Ben Mah is offline Ben Mah  Canada
I would think resistance between input positive and ground would be very high, so something is wrong.
I suppose there could be a path to ground through JFET gate to source if shorted or gate to drain if shorted, or through D3 or D4 if they are shorted, or through R2 if shorted.
I don't have a meter like Chip's so I don't know what the readout means. I would set the meter to measure Resistance rather than Continuity to be sure of the measurement.
Old 22nd July 2021, 09:29 PM   #2782
andynor is offline andynor  Norway
Brainfart on my part, not unusual. Glad Ben stepped in! I have measured using the beep mode on a Fluke. If I am not mistaken, a beep means low resistance/good continuity. But I am not sure the R shown there is the actual R between the two, so excited to hear what the measurements are in resistance mode.
Burning Amplifier 3 / Wayne’s linestage / Bryston BDA-1 fed by RPI / Fyne Audio F502
Old 22nd July 2021, 10:13 PM   #2783
Dennis Hui is offline Dennis Hui  Canada
Hoopy Frood
Chiptech,
Please confirm those measurements in resistance mode for both channels.
On post #2775
( A guide to building the Pass F4 amplifier. ) you stated the same (negative) values for both,
yet commented they are very different.
We are fearless amplifier builders. A little heat doesn't scare us at all.
- NP 2002
Old 22nd July 2021, 10:17 PM   #2784
Nice, this will lead to a solution I am sure. At least if the resistance mode shows something interesting.
Dennis: in post #2770 Chip posted readings of 7R3 for the left channel input, but prolly not in R mode. Anyways, divergence was around 32R.
Old 22nd July 2021, 10:25 PM   #2785
Hoopy Frood
My mistake.
I would still suggest a re-measurement in resistance mode since it's not clear what a
negative resistance value means.
Anyway, I'll bow out for now.
- NP 2002
Old 22nd July 2021, 11:54 PM   #2786
ZUM911 is offline ZUM911  Australia
There is something weird with the negative resistance. It indicates that there is current in the circuit. If the amp is off during the measurement there shouldn't be any current flow. Be sure any residual voltage in the supply caps is drained before making the measurements.
Old Yesterday, 09:42 PM   #2787
Chiptech is offline Chiptech  United States
Originally Posted by thimios View Post
Are you sure that you haven't burn the input rca applying very hot airon for a long time?
I was on the road for past four days.
Today I checked continuity for left/right all RCA connects on input/output and got beeps across the board, including inside/outside of back panel.
Amp Camp Amp - Pass F5 - Korg Nutube Preamp - Pass M2x w Tucson - Ishikawa DBs - Pass F6 - Elekit 300B
Old Today, 05:18 AM   #2788
I was out of town since Thursday. Today I went back and read thru all the posts since #2725.
And I came up with new measurements for both channels, with power on and with power and signal in from Pre-amp [I've tested the Pre-amp many times and it delivers a signal to the left channel].
Looking at the numbers - the left R5 has a lower value than the right with the signal in on 1.167 vs. 5.727, but not sure what that might indicate?
Old Today, 10:12 PM   #2789
It indicates less current than through the right channel equivalent resistor. You need help from bigger Boyz, but as far as I can tell it might affect / be caused by what’s happening at the drain of Q2. An obvious and possibly unnescessary question is: sure that R5 is 1k and R22 750R? And is the voltage at the negative input of the PCB the same as at the negative rail of the PSU?
Good luck! Hope the AC is working…
Andy
Old Today, 10:15 PM   #2790
The left chan consistently has about 3 volts less than the right chan, at several measuring points. Strange… not only the R5 measurement is funny…
  Reply to this post
A guide to building the Pass F4 amplifier.Hide this!Advertise here!
Thread Tools
An illustrated guide to building an F5 6L6 Pass Labs 1849 1st June 2021 06:37 PM
A Concise Guide to the Published Amplifier Circuits of Nelson Pass rsdio Pass Labs 59 13th April 2021 06:32 AM
My,PASS ALEPH J and f4 xr000 Pass Labs 1 25th December 2009 03:20 AM
Idiot´s guide to building Pass amps? judge Pass Labs 3 19th December 2004 11:33 PM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
Copyright ©1999-2021 diyAudio
