A guide to building the Pass F4 amplifier.
A guide to building the Pass F4 amplifier. Please consider donating to help us continue to serve you.
Old 2nd December 2019, 04:09 PM   #1591
ItsAllInMyHead is online now ItsAllInMyHead  United States
@Belmondo - Follow the advice provided. I made the error of ordering a close, but not quite part. TLV431ILPR... This wonderful community helped me realize and correct the error of my ways after my MOSFETs wouldn't kick in. Low Voltage version ... nope... nope... nope. Oops
Old 2nd December 2019, 04:34 PM   #1592
Zen Mod is online now Zen Mod  Serbia
Official Court Jester
Zen Mod's Avatar
well , in your case prefix was culprit, not suffix
my Papa is smarter than your Nelson !
clean thread; Cook Book;PSM LS Cook Book;Baby DiyA ;Mighty ZM's Bloggg;Papatreasure;Papa...© by Mighty ZM
Old 2nd December 2019, 05:34 PM   #1593
Belmondo is offline Belmondo
Thanks again for all the advice, much appreciated, especially by ItsAllInMyHead. I did read about you prefix problem which is why I started paying attention to the types of TL-431. 6L6ís recommended part is now in my BOM
Iím now at the last hurdle with my BOM. Trim-pots. Bourns has different pin configuration - straight and offset - all have 3 pins but there are 4 holes on the pcb for the trim pots. Little things like this completely throw a beginner!
Are there 4 holes so I can use trim pots with either the 3 pins in-line or those with the pins off-set? I donít want to buy the wrong ones as they are relatively expensive and then thereís the carriage cost on top for a re-order if I'm wrong! Iím looking to buy this: 3296W-1-502LF Bourns | Mouser Российская Федерация
and the 500 ohm version. Thanks again for your help. Iíd be lost and pulling out whatís left of my hair without it!
Old 2nd December 2019, 05:37 PM   #1594
Shawnstium is offline Shawnstium  United States
The extra hole is to allow the use of both in-line and off-set pin trim pots.
Old 2nd December 2019, 05:44 PM   #1595
Thanks Shawnstium
Old 2nd December 2019, 06:55 PM   #1596
@belmondo - if you're so inclined. If I had it to do over again, I'd have put in the pots with the adjustment on the side. I can't remember if the F4 boards have both in-line and Y configuration, but something like this makes it so much easier to adjust the bias and offset. I couldn't find the exact part I was looking for, but someone with better Mouser-Fu skills may be able to jump in with the exact part number for both pots.
Old 2nd December 2019, 07:00 PM   #1597
Zen Mod's Avatar
boyz
use tweezers , if pins are different than holes line-up
I would do it even for medical instruments, I did it zillion times repairing money-making gadgets ......
Old 2nd December 2019, 07:20 PM   #1598
Blk Dynamite is offline Blk Dynamite  United States
I need to build this one. Think ill give my dad my M2x and build this for myself
Old 2nd December 2019, 08:39 PM   #1599
@ItsAllInMyHead: I've found a top adjusting trim pot on Mouser(Bourns call it vertical adjusting) and the Y-version is available so that's what I'll go for as long as the values are available.
Thanks again.
Old 2nd December 2019, 09:15 PM   #1600
@ItsAllInMyHead:Here are the Mouser part numbers should you fancy a change
652-3296Y-1-502LF
652-3296Y-1-501LF
A guide to building the Pass F4 amplifier.Hide this!Advertise here!
An illustrated guide to building an F5 6L6 Pass Labs 1220 24th November 2019 10:29 PM
A Concise Guide to the Published Amplifier Circuits of Nelson Pass rsdio Pass Labs 55 6th November 2018 06:40 PM
My,PASS ALEPH J and f4 xr000 Pass Labs 1 25th December 2009 04:20 AM
Idiotīs guide to building Pass amps? judge Pass Labs 3 20th December 2004 12:33 AM
Copyright ©1999-2019 diyAudio
