A guide to building the Pass F4 amplifier.
Old 10th August 2019, 10:24 AM   #1411
kecapmanis021 is offline kecapmanis021  Indonesia
kecapmanis021's Avatar
Originally Posted by Shawnstium View Post
OKAY... I will just leave the Vishay AC series in and save the money. I am going to buy more mosfet to hopefully get their current draw closer together.
Afaik Vishay AC is inductive wirewound. IMO Panasonic ERG in standard BOM is a better choice, or Koa BPR metal plate resistor.
~Kecap
Old 10th August 2019, 06:09 PM   #1412
gdglenn201 is offline gdglenn201  United States
Would anyone mind making some suggestions on chassis wire gauges and types solid vs. stranded etc?
Old 10th August 2019, 06:55 PM   #1413
SoundEros5 is offline SoundEros5
Default Bias Adjustment - 0
Finally completed Pow Supply and F4 Boards. The less light up. However, I am reading .6 ohms across the .47 ohm resisters, and 0 VDC no matter how I turn the P1 variable resister. Any suggestions?
Old 10th August 2019, 06:56 PM   #1414
The text should have read, "The leds light up."
Old 10th August 2019, 07:02 PM   #1415
Zen Mod is online now Zen Mod  Serbia
Official Court Jester
Zen Mod's Avatar
all power lines 1.5 or 2,5 sq. mm , more the merrier ; nice stranded ......... solid is no-no there , not overly clever when dealing with pcbs
input signal - I'm using 0.2mm dia solid core , silvered copper
tricky to read anything sane cross R source , when same is in circuit , not taking in account possibility that you either have lousy DMM or lousy battery in same
regarding Iq - ( voltage readout across Rs) - you need two DVMs - one across output to observe output DC offset , and second across any Rs , to read voltage , thus Iq
pictures could help , also some measurement values , not even mentioning how important is to point us to your ref. schmtc
my Papa is smarter than your Nelson !
clean thread; Cook Book;PSM LS Cook Book;Baby DiyA ;Mighty ZM's Bloggg;Papatreasure;Papa...© by Mighty ZM
Old 11th August 2019, 05:45 PM   #1416
I think I found the problem—at least I hope so.
I used a 22.1 ohm resister in R8 instead of the specified 22.1K
We'll see if that gives me a reading greater than 0 across the .47R source resisters.
Thank you, Zen Mod!
Old 11th August 2019, 07:08 PM   #1417
Zen Mod's Avatar
A guide to building the Pass F4 amplifier.Hide this!Advertise here!
An illustrated guide to building an F5 6L6 Pass Labs 1185 4th April 2019 03:42 AM
A Concise Guide to the Published Amplifier Circuits of Nelson Pass rsdio Pass Labs 55 6th November 2018 05:40 PM
My,PASS ALEPH J and f4 xr000 Pass Labs 1 25th December 2009 03:20 AM
Idiot´s guide to building Pass amps? judge Pass Labs 3 19th December 2004 11:33 PM
Copyright ©1999-2019 diyAudio
