A guide to building the Pass F4 amplifier.
Old 15th May 2019, 10:01 PM   #1251
Mark Johnson is offline Mark Johnson  United States
Mark Johnson's Avatar
It helped me understand the F4 circuit design better, after I drew the schematic diagram all spread apart, as shown below. In case it helps other members, here you go.
Nelson uses rail boosters in several of his amplifiers, including the "A20" Class-A DIY amplifier, published in 1974 (!). He seems to like them.
Please remember that this amplifier was designed by initials N.P. and not by initials M.J. If you want to ask "why did you do X rather than Y?" be sure to address your question to the correct person.
_
Old 15th May 2019, 11:32 PM   #1252
cal3713 is offline cal3713
_
Ohh yeah, I need that. Thanks.
And I replaced my burned out resistor, tried the bulb limiter and got a bright bulb. Just ordered a new board and am going to mouser to get a new set of parts. Will just build a complete replacement for that channel.
Am going to cross my fingers and hope that the mosfets and jfets can be salvaged.
Old 16th May 2019, 12:46 AM   #1253
BigE is offline BigE  Canada
BigE's Avatar
How well matched are the mosfets? F4 manual says the MOSFETs in the first watt product are matched Vgs to 0.02v.
Also, check the f5t build thread. At the end I posted a link on how to check your MOSFETs with a dmm.
Old 16th May 2019, 02:59 AM   #1254
I got the MOSFETs from alweit on ebay as recommended somewhere on the thread. I'll check the numbers tomorrow and report back...
Old 16th May 2019, 03:08 AM   #1255
6L6 is offline 6L6  United States
6L6's Avatar
Alweit is a good seller and I doubt thats the issue. I'd really like to see some good photos of the back of the PCB.
Old 16th May 2019, 12:09 PM   #1256
BigE's Avatar
It's easy to check the matching. Just measure the voltages across the source resistors. They should be the same for each polarity.
Old 16th May 2019, 01:16 PM   #1257
Should I be soldering both sides of the PCB??
There's not really much happening back there because I soldered everything on top except the caps, the variable resisistors, the JFETS, and the shunt regulator...
Old 16th May 2019, 01:17 PM   #1258
I can take better photos later today after pulling the offending board... (not sure which of those above is actually the bad one)
Old 16th May 2019, 01:56 PM   #1259
BigE's Avatar
It's best if the leads of the parts are soldered directly to the traces that are the circuit.
Old 16th May 2019, 02:18 PM   #1260
6L6's Avatar
...maybe? It depends on how good a solderer you are.
What solder are you using? Is it lead-free? Might be part of the issue.,,
A guide to building the Pass F4 amplifier.Hide this!Advertise here!
An illustrated guide to building an F5 6L6 Pass Labs 1185 4th April 2019 03:42 AM
A Concise Guide to the Published Amplifier Circuits of Nelson Pass rsdio Pass Labs 55 6th November 2018 05:40 PM
My,PASS ALEPH J and f4 xr000 Pass Labs 1 25th December 2009 03:20 AM
Idiotīs guide to building Pass amps? judge Pass Labs 3 19th December 2004 11:33 PM
Copyright ©1999-2019 diyAudio
