Transistor Dissipation and Turbo Projects
Old 5th May 2016, 05:03 AM   #41
sangram is offline sangram  India
The difference between 200 and 300 is the efficiency of a linear supply. As such, both figures are absolutely correct.
Old 5th May 2016, 06:29 AM   #42
el_mariachi is offline el_mariachi  Norway
Originally Posted by 2 picoDumbs View Post
(89-25)/4 = 16
12 16 = 192W
Zen Mod was being a funny man. 42 is the answer to life, the universe, and everything.
I was almost able to understand Zen Mod's joke
But in the example (below) there is a difference between:
TJ=16 * (1 + 1 + 2) +25
and TJ = 116
16 * 4 + 25 = 89
But Tj is 116
116 - 89 = 27
And now i can't sleep, what is this 27 and where did it come from?
Originally Posted by Nelson Pass View Post
In our Aleph 2 example
Tj = 16 * (1 + 1 + 2) -25
Tj = 116 deg C.
And this is why Aleph 2's don't break.
Old 5th May 2016, 07:51 AM   #43
2 picoDumbs is offline 2 picoDumbs  Australia
2 picoDumbs's Avatar
Tj is not 116. That was a simple calculator mistake.
"If you leave this point unattached to some circuitry, an ideal constant current source will emit a small lightning bolt which will travel until it connects to something." Nelson Pass
Old 5th May 2016, 08:25 AM   #44
I tought this was the calculator mistake:
Yes, should have been +25, and old calculator.
(me)
Old 5th May 2016, 10:01 AM   #45
Yeah that was another one.
64 + 25 = 89
Old 5th August 2017, 11:13 AM   #46
Keratherm claim the thermal resistance (Rth) of their red 86/82 thermal pads is around 0.1 K/W. http://www.kerafol.com/fileadmin/use...r_TM_86_82.pdf
Has anyone had a chance to confirm it?
I did a quick comparison verse generic silcone thermal pads and the keratherm pads are significantly better.
Old 5th August 2017, 11:55 AM   #47
R.I.P.
I think it was EUVL that did a comparison in one of his papers attached to the F5x Thread.
regards Andrew T.
Old 5th August 2017, 11:59 AM   #48
R.I.P.
I reported an anomaly a few years ago when in the testing phase of a paralleled output stage of a power amplifier.
I ran out of plastic/silicone insulators and used some thin mica to complete the test assembly.
The currents through the various paralleled devices were very different !
It was the lower temperature of the mica mounted insulators that caused the Vbe to be higher and this reduced the current in the mica mounted devices.
The silicone mounted devices thus had to pass a higher proportion of the current and as a result had to run even hotter, exaggerating the unbalance.
Changing to all mica mounted removed the unbalance in the 3pair output stage.
regards Andrew T.
Old 5th August 2017, 12:05 PM   #49
This is the sought of thing I have observed also.
Old 10th October 2018, 10:23 PM   #50
astromo is offline astromo  Australia
Thanks Nelson. Setting out this detail clears up a few unknowns for me.
Equations work for me. I may not be an Elec Eng but heat transfer is part of what I do.
Transistor Dissipation and Turbo ProjectsHide this!Advertise here!
Multiple transistor heat dissipation. Boscoe Solid State 3 22nd November 2011 10:11 PM
Transistor power dissipation Neutrality Solid State 2 19th December 2010 04:41 PM
Transistor power dissipation xeclipse Solid State 1 18th December 2010 05:16 PM
Output transistor power dissipation. nigelwright7557 Solid State 11 26th May 2008 01:55 PM
