AB100 Class AB Power Amplifier
Old 17th August 2019, 06:00 PM   #661
Karl vd Berg is offline Karl vd Berg
Karl vd Berg's Avatar
From OnSemi and ST manufacturers' datasheets, I see slightly different internal schematics from each TIP142 and TIP147 (resistors)...
Which of them is preferable?
Old 17th August 2019, 06:04 PM   #662
osscar is offline osscar  Latvia
osscar's Avatar
For me ON semi seems little better..
My DIY so far: two Leach amps,two Pass AB100, Pass F5, B1 buffer, Hiraga le monstre, two LM3875, LM1875, OPA549, 6C33C SE, GU32 PP, 6p3c-e PP, Marsh headphone amp.Phono - OBH-8se, Pacific RIAA, inDiscreet Phono, MF A1 Clone, Whammy headphone amp.
Old 17th August 2019, 06:06 PM   #663
Mark Johnson is offline Mark Johnson  United States
Mark Johnson's Avatar
Build Left channel with ST devices and Right channel with On Semi devices. Listen to each (in mono). If you have a strong preference, implement that in both channels. If you don't have a strong preference, leave the amp alone and start listening in stereo.
Old 17th August 2019, 07:02 PM   #664
Thanks, Osscar!
Mark Johnson, very interesting idea! Could also mix the 2 manufactures' parts.
Old 17th August 2019, 07:34 PM   #665
prasi is offline prasi  India
prasi's Avatar
most probably you wont be able to detect any differences in sound
My revamped site https://sites.google.com/site/analogdesign1234/
Old 20th August 2019, 12:13 AM   #666
Freecrowder is offline Freecrowder  United States
So Osscar, I have not built a stereo pair yet to listen to in my system. I will compare the A40 to the AB100 when I do. I have had the A40 for over 10 years and it is the best amp I own right now. I also have the Honeybadger and it is a close second. I need the power though for running maggies.
Old 20th August 2019, 07:23 PM   #667
osscar's Avatar
thank you for information.
AB100 Class AB Power AmplifierHide this!Advertise here!
"The Wire AMP" Class A/AB Power Amplifier based on the LME49830 with Lateral Mosfets opc Solid State 2620 13th November 2018 10:23 PM
Contest: Linear Power Amp in a mint tin (class Aa, class AB, or class B) danielwritesbac Chip Amps 206 19th January 2013 08:52 PM
It helps to select best class power amplifier (AB- 40-50 watts) lopezm0 Solid State 59 16th December 2012 04:13 PM
DIY Low Power Class A (or AB) amplifier suggestions gareth Solid State 2 16th June 2009 02:46 PM
A good Brazilian Amplifier, class A switching to AB in hi power destroyer X Solid State 65 24th March 2005 08:12 PM
Copyright ©1999-2019 diyAudio
