AB100 Class AB Power Amplifier
Old 8th July 2019, 03:41 AM   #591
prasi is offline prasi  India
prasi's Avatar
Originally Posted by Freecrowder View Post
Yes Mark I did look at and measure the footprint. Looking on Mouser I'm finding everything slightly different. I'm just wondering if anyone knew immediately to save me some time. I'm sure there are many it just searching through them.
Measure the distance between center hole and other holes of the trimpot on the PCB , if its 2.54mm, then a Bourn's 3299Y would fit.
https://www.bourns.com/pdfs/3299.pdf
My revamped site https://sites.google.com/site/analogdesign1234/
Old 8th July 2019, 01:24 PM   #592
SRMcGee is offline SRMcGee  United States
SRMcGee's Avatar
Folks:
I'm a little late to the party, but if anyone has a spare set of AB100 boards kindly PM me.
Scott
Good decisions come from experience. Experience comes from making bad decisions. (Mark Twain)
also, Everyone has a plan, till they get punched in the mouth. (Mike Tyson)
Old 11th July 2019, 07:12 PM   #593
osscar is offline osscar  Latvia
osscar's Avatar
A little progress - hopefully at the end of the weekend I will finish it - still have to find a nice piece of wood - for front panel.
My DIY so far: two Leach amps, Pass AB100, Pass F5, B1 buffer, Hiraga le monstre, two LM3875, LM1875, OPA549, 6C33C SE, GU32 PP, 6p3c-e PP, Marsh headphone amp.Phono - OBH-8se, Pacific RIAA, inDiscreet Phono, MF A1 Clone, Whammy headphone amp.
Old 11th July 2019, 10:36 PM   #594
mpmarino is offline mpmarino  United States
mpmarino's Avatar
I love the DIY spirit, osscar!
Crazy Yankee.
Old 12th July 2019, 05:40 PM   #595
osscar's Avatar
Yes there is some addiction that even at night i think - what to do better, how to organize wires etc..
everything done - only transistors left to solder - delivery of heat-sinks is delayed, i do not want to solder transistors without them - i can miss the right height ..
Old 13th July 2019, 08:15 PM   #596
osscar's Avatar
The front panel is also sorted - there will be a Brazilian cherry wood panel...progress so far:
Old 14th July 2019, 01:34 PM   #597
osscar's Avatar
still waiting delivery of front panel Leds ( blue ones of course) and mains switch
Old 14th July 2019, 01:51 PM   #598
Skylar88 is offline Skylar88  South Africa
Fugly
Old 14th July 2019, 01:54 PM   #599
vdi_nenna is offline vdi_nenna  United States
vdi_nenna's Avatar
Nice!
I build, therefore I am.
AB100 Class AB Power AmplifierHide this!Advertise here!
"The Wire AMP" Class A/AB Power Amplifier based on the LME49830 with Lateral Mosfets opc Solid State 2620 13th November 2018 10:23 PM
Contest: Linear Power Amp in a mint tin (class Aa, class AB, or class B) danielwritesbac Chip Amps 206 19th January 2013 08:52 PM
It helps to select best class power amplifier (AB- 40-50 watts) lopezm0 Solid State 59 16th December 2012 04:13 PM
DIY Low Power Class A (or AB) amplifier suggestions gareth Solid State 2 16th June 2009 02:46 PM
A good Brazilian Amplifier, class A switching to AB in hi power destroyer X Solid State 65 24th March 2005 08:12 PM
Copyright ©1999-2019 diyAudio
