AB100 Class AB Power Amplifier
Thread Tools
Old 31st May 2019, 08:57 PM   #491
rookakoma is offline rookakoma  Hungary
rookakoma's Avatar
Originally Posted by Nelson Pass View Post
Not to step on toes, but here are my files.
Board is 2.85" x 9.725" and the Gerbers are in the format that pcbway.com
seems to be happy with.
I recommend the jlcpcb, which is cheaper than pcbway.
The quality is really good, we used it regularly for production at Norma Instruments. 5 boards is 10 USD+ shipping, which is 25 USD whith DHL.
They are very fast and professional.
For example:
First Watt F7 review
F5 Turbo
Old 1st June 2019, 10:23 PM   #492
Skylar88 is offline Skylar88  South Africa
Skylar88's Avatar
I intend to use this as a plate amp for a sub. Will it be viable to mount it on a piece of flat aluminum or is a finned heatsink required? If the latter, what size heatsink?
Question 2: What VA rating is recommended for the transformer?
Old 2nd June 2019, 09:18 AM   #493
carsten.witt is offline carsten.witt  Germany
carsten.witt's Avatar
Dear mr Pass (Papa),
first thanks for all your effort for the diy community and also thanks for the files!
I ordered today 10 Boards and i will send to others diy friends here for postage and a little fees (like for an padded envelope, if there will be customs charge the i share it on the 10 boards, it is Germany and here nobody knows how the customs "ticks" ;-) ).
Regards ........Carsten
Old 2nd June 2019, 09:29 AM   #494
osscar is offline osscar  Latvia
osscar's Avatar
Good work !!!
My DIY so far: two Leach amps,two Pass AB100, Pass F5, B1 buffer, Hiraga le monstre, two LM3875, LM1875, OPA549, 6C33C SE, GU32 PP, 6p3c-e PP, Marsh headphone amp.Phono - OBH-8se, Pacific RIAA, inDiscreet Phono, MF A1 Clone, Whammy headphone amp.
Old 2nd June 2019, 11:57 AM   #495
manniraj is offline manniraj  India
I will be interested in a pair of boards but do let me know how much does it cost for shipping in a padded envelope to India and also the cost of the pair of boards.
Old 2nd June 2019, 12:20 PM   #496
@manniraj,
ok, will do so if I hold the boards in my hands.
Old 2nd June 2019, 12:58 PM   #497
Danger Mouse is offline Danger Mouse  Germany
Danger Mouse's Avatar
how thick you have choosen the copperlayer 32Ám? or 70Ám
Old 2nd June 2019, 01:04 PM   #498
1oz = 35ym, i will solder a wire along the power lines but I think it would be enough.
Old 2nd June 2019, 01:20 PM   #499
@All,
please write your name here in the thread, makes it easier for me, thanks!
But, please thing about that some PCB factories have a "welcome bonus", that would be in some cases cheaper the the shipping and so.
1. manniraj
2. Cambe
3. Robbie
4. Dieter
[EDIT] So all boards are gone, if some one goes away from this I will post it here
Old 2nd June 2019, 06:50 PM   #500
Originally Posted by carsten.witt View Post
@All,
Yes exactly my point, so please let us know the total cost of these boards shipped. I am not sure if printing them from China makes it cheaper including shipping.
thanks
AB100 Class AB Power AmplifierHide this!Advertise here!
Thread Tools
"The Wire AMP" Class A/AB Power Amplifier based on the LME49830 with Lateral Mosfets opc Solid State 2634 3rd March 2020 01:44 AM
Contest: Linear Power Amp in a mint tin (class Aa, class AB, or class B) danielwritesbac Chip Amps 206 19th January 2013 09:52 PM
It helps to select best class power amplifier (AB- 40-50 watts) lopezm0 Solid State 59 16th December 2012 05:13 PM
DIY Low Power Class A (or AB) amplifier suggestions gareth Solid State 2 16th June 2009 03:46 PM
A good Brazilian Amplifier, class A switching to AB in hi power destroyer X Solid State 65 24th March 2005 09:12 PM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
Copyright ©1999-2020 diyAudio
