AB100 Class AB Power Amplifier
Old 13th April 2019, 01:09 PM   #441
Abx74 is offline Abx74  France
Hi everyone,
Is someone have some PCB in stock ? I'd like to get some to built one... Summer is coming...
Damien
Old 13th April 2019, 04:27 PM   #442
osscar is online now osscar  Latvia
osscar's Avatar
The officiall PCB is not yet made .... I think this amplifier is underestimated (perhaps due to dartlington output and class AB ) and forgotten - but it sounds great !!!
My DIY so far: two Leach amps, Pass AB100, Pass F5, B1 buffer, Hiraga le monstre, two LM3875, LM1875, OPA549, 6C33C SE, GU32 PP, 6p3c-e PP, Marsh headphone amp.Phono - OBH-8se, Pacific RIAA, inDiscreet Phono, Whammy headphone amp.
Old 13th April 2019, 05:00 PM   #443
gdan is offline gdan  Greece
Nelson,
any news about this amplifier ?
It will be a nice project for those of us with active loudspeakers that need a lot of power amplifiers and Class A is not a very practical option.
Old 14th April 2019, 01:51 AM   #444
RafaPolit is offline RafaPolit  Ecuador
RafaPolit's Avatar
Originally Posted by gdan View Post
Nelson,
...It will be a nice project for those of us with active loudspeakers that need a lot of power amplifiers and Class A is not a very practical option.
??? Could you elaborate how you use an amp with active loudspeakers? Do you mean bypassing the internal amp? Which speakers would that be?
Thanks,
Rafa.
Old 14th April 2019, 04:11 AM   #445
reggieSf25 is offline reggieSf25  United States
Nelson,
Old 15th April 2019, 09:27 AM   #446
I am talking for DIY loudspeakers with active crossovers.
Mine is four way and it is not very practical to use eight Class A power amplifiers.
Old 16th April 2019, 04:08 AM   #447
meanie is offline meanie  Singapore
I experienced some humming from my freshly built M2X, can't determine if i had ground loop induced hum or transformer induced hum. So i did the followings...
Shifting my left channel heatsink block around while keeping the right channel where it should be.
I have to block the left channel with a iron chassis and even at an angle to the power supply board/transformer, to finally get a totally quiet left channel.
I now think that i may have to make partitions in the chassis that i m going to fit my M2X into, other than using Mumetal cover for the Edcor trans.
I will try twisting those transformer secondary output cables next.
Marantz 7 clone(25 years old) - BabyHuey EL34s - BA3FE - 2ACA - F6 - M2X - 2Whammy - USSA5.0 - Yarra Preamp(in progress)
Old 16th April 2019, 04:40 AM   #448
Very sorry i posted on wrong thread.
AB100 Class AB Power AmplifierHide this!Advertise here!
"The Wire AMP" Class A/AB Power Amplifier based on the LME49830 with Lateral Mosfets opc Solid State 2620 13th November 2018 10:23 PM
Contest: Linear Power Amp in a mint tin (class Aa, class AB, or class B) danielwritesbac Chip Amps 206 19th January 2013 08:52 PM
It helps to select best class power amplifier (AB- 40-50 watts) lopezm0 Solid State 59 16th December 2012 04:13 PM
DIY Low Power Class A (or AB) amplifier suggestions gareth Solid State 2 16th June 2009 02:46 PM
A good Brazilian Amplifier, class A switching to AB in hi power destroyer X Solid State 65 24th March 2005 08:12 PM
Copyright ©1999-2019 diyAudio
