Aleph J for Universal Mounting Spec
Old 5th September 2020, 08:21 PM   #821
RainfallSky is offline RainfallSky  Russian Federation
RainfallSky's Avatar
Originally Posted by mbrennwa View Post
The bigger the more they will act as an antenna that picks up noise. I'd recommend to stay away for physically big caps if/where possible.
Maybe I should chose something smaller for С6, С7.
Still want C1 to be big axial cap.
Not rediculously big cap ofcourse.
This was motivation factor to learn new things like KiCad..
Old 5th September 2020, 08:36 PM   #822
6L6 is offline 6L6  United States
6L6's Avatar
The film bypass capacitors (C6, C7 on your board) will be removed on the next revision of Store PCBs. They are not necessary.
I'd also add a second terminal blade near ground if people want to connect speaker - on the amplifier PCB. Sometimes it's quieter to do that.
That said, C1 should be film. Add a bunch of extra holes so people can use reasonable sized capacitors or big ones, as example here;
Old 5th September 2020, 09:26 PM   #823
Definitely will add GND terminal blade
And think what to do whith C6, C7.. get rid of or use something more compact.
Will gather info for now and start to make changes a bit later.
Thank you!
Old 14th September 2020, 12:25 AM   #824
Some changes.
Small resistors up to RN60 size except LED risistors RN55 size.
C1 have 69.5mm lead space for big axial capacitor or 37.5mm 27.5mm 22.5mm 15mm for capacitors like FKP4 or regular MKP.
(Hole size for axial capacitor is 1mm because it was meant for specific cap with 0.8mm lead but can make it biger for versality)
C6,C7 stay. Lead space 22.5mm 15mm 5mm from FKP4 to small film caps.
Redraw silkscreen for some parts.
Q2, Q3, Q4 now ZTX/BC friendly with BCE marking.
Still only left channel board (74x260mm).
Will start to draw right channel when layout for left channel settle.
Already made change for Q2 E layout line after this scheenshots..
Still could be errors I can't see right now.
Like would LED's light connected that way.
Old 15th September 2020, 11:33 AM   #825
eddyvb is offline eddyvb  Belgium
The line to the gate of q1a is quite long, maybe put an optional gate stopper resistor close to the gate?
And a question, the silkscreen text ‘Aleph J’, is it a Kicad font? Would be a nice engraving this nice font on the frontplate.
Old 16th September 2020, 12:15 AM   #826
Not sure. But could be done about 2cm closer.
Silk screen for Aleph J is not KiCad font.
I convert it to silk screen symbol in KiCad from screenshot I made of what I type in MS Word using a real font..
Font name is "The Doctor".
I also plan to make it as a copper pad without mask later.
Should look cool with ENIG and kind of meh with HASL.
Old 16th September 2020, 06:31 AM   #827
Thanks for the font RainfallSky!
Old 16th September 2020, 11:53 PM   #828
I gave up to make it as left and right pcb's and copycat inputs location from Didiet layout.
It went much beter and could be used as one board for both channels.
Board also decreased in size to 250mm x 74mm.
Old 17th September 2020, 08:55 AM   #829
Try to optimize the part placement for shorter tracks. e.g.
Rotate 180 R25, put above r26
C2 asks to be next/rotated to r26
move r24 r27 and trans to the left, maybe rotate
move trans next to r14 r15?, and move them left
resistor? connected to r7 move left
the big cap is difficult, it asks to be in the top middle of the pcb, but it's big..
where possible copy high current tracks to other layer
Maybe add the "Algar" mods c102 c105, a few small caps, search the forum for info. I've made a smd aleph pcb version with these mods, because I could not get the original stable at full power and high freq.
Old 17th September 2020, 12:27 PM   #830
Thank you for a lot of valuable sugestions!
I have some ideas to make it more compact.
Will post what I got later.
Aleph J for Universal Mounting SpecHide this!Advertise here!
Universal Mounting Specification rsdio Construction Tips 3 31st October 2011 11:51 AM
what is the mounting depth and mounting diameter of this? lemans23 Multi-Way 2 26th October 2005 10:52 PM
Has anybody built an Aleph-x to this spec??? D3 Pass Labs 58 16th June 2004 06:08 PM
Spec on transformer for Aleph 5? Tony D. Pass Labs 8 24th April 2002 12:49 PM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
Copyright ©1999-2020 diyAudio
