Aleph J for Universal Mounting Spec
Old 4th September 2018, 10:28 PM   #751
Extreme_Boky is online now Extreme_Boky
Can you have that 4U 400mm Dissipate chassis with UMS heatsinks? I like the 400mm depth and 40mm heatsinks, but I don't think you can get 2 X 200mm heatsinks (per each side) with "UMS" pre-drilled holes..??
Anyone?
Old 4th September 2018, 10:52 PM   #752
Zen Mod is offline Zen Mod  Serbia
Official Court Jester
Zen Mod's Avatar
what I'm seeing in UMS pdf , I understand as UMS is made for both 300 deep and 400 deep
excluding one central hole , no reason why 400 deep can't be made from two pieces ..... however exact deal/arrangement can confirm only someone from DiyA/Store team
ask them in Store related threads
my Papa is smarter than your Nelson !
clean thread; Cook Book;PSM LS Cook Book;Baby DiyA ;Mighty ZM's Bloggg;Papatreasure;Papa... by Mighty ZM
Old 7th December 2018, 10:48 AM   #753
D.Achenbach is offline D.Achenbach  Germany
Is it really necessary to hava 4 Units height or is a 3H 400mm Chassis also OK for a two channel Aleph J?
I love the smaller width of the Mini Dissipantes. The space inside for the power supply is more than enough in there.
Plannes is to use Kapton Isolators for the FETs which should Keep them cooler and eventually a thick copper "heatspreader under them.
Dieter
Old 7th December 2018, 11:11 AM   #754
Zen Mod's Avatar
you can squeeze it even in 2U/300
then fans are your only option
for 3U/400 ..... summer in Europe - Babysitter is a must
Old 7th December 2018, 12:07 PM   #755
henryve is offline henryve  South Africa
henryve's Avatar
If you again have the same summer temperatures you had this past summer in Europe, my suggestion is, no.
Biggest enemy to heatsink doing a good job is ambient temperature.
Old 7th December 2018, 12:23 PM   #756
Thanks for your replies.
That's true, it was a hot summer, but I loved it.
It will not be the only amp here. If it's too hot I can use a Hypex class-D amp instead.
Dieter
Aleph J for Universal Mounting SpecHide this!Advertise here!
Universal Mounting Specification rsdio Construction Tips 3 31st October 2011 12:51 PM
what is the mounting depth and mounting diameter of this? lemans23 Multi-Way 2 26th October 2005 11:52 PM
Has anybody built an Aleph-x to this spec??? D3 Pass Labs 58 16th June 2004 07:08 PM
Spec on transformer for Aleph 5? Tony D. Pass Labs 8 24th April 2002 01:49 PM
